My '51 F1 build (Updated Old Skool Hot Rod) - Page 2 - Ford Truck Enthusiasts Forums
Old 06-10-2012, 03:14 PM
bk53's Avatar
bk53 bk53 is offline
bk53 is starting off with a positive reputation.
wow, lucky truck she'll see another 60 years after this treatment. I'm thinking of stripping what trim my 53 has off. It's a pain to work around, and its kind of obvious what it is. The fenders are a dead giveaway I guess stripping trim would be a lot simpler on a 53.
Old 06-11-2012, 01:22 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Quote:
Originally Posted by Bobby41909 View Post
I'd also like to get the deluxe trim and I've seen several versions (I am not an expert) for the hood. I have the single spear and would like to expand that with the upper and lower bars. The hood is so tall I think it looks better with that upgrade.
Anyonw know where I can get a good set? My spears are in great shape so I only need the others with the clips.
The front "arrows" for the trim are available in reproduction. You just need the four "extra" bars. I have them. You can email me at modelking2000 at hotmail dot com.
Old 06-11-2012, 10:19 AM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
Looks really great. Who makes those finned valve covers? Cal Custom? I want the same type on mine. Nice job on the tranny cover fab, looks good. Great job
Old 06-11-2012, 10:51 AM
HEAVY100's Avatar
HEAVY100 HEAVY100 is offline
HEAVY100 is gaining momentum as a positive member of FTE.
Thats a great build
Old 06-11-2012, 12:34 PM
Bobby41909 Bobby41909 is offline
Bobby41909 is starting off with a positive reputation.
Quote:
I found them on Ebay...search "ford 302 finned valve covers". They are really nice and only cost $83. Got the air cleaner the same way
Old 06-11-2012, 07:48 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is online now
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Wow 1,2,3, you make it look easy, I guess thats the difference between Me an amature, and you oviously not an amature. Nice planning, nice workmanship = a very nice truck. Im looking forward to watching you as you progress. Nice!
Old 06-12-2012, 10:18 AM
Moe Craig's Avatar
Moe Craig Moe Craig is online now
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
A few more:
Nice job. I like to ask about the AC vents. Can you tell me about them? They are going to look great in their. Second is the the top hole in the dash, where the speaker goes, is that where the AC controls go? What kind of control are you going to use?
Old 06-12-2012, 10:57 AM
Quote:
The A/C is a universal kit from Vintage Air (actually got it from Summit since they recently became a distributor...great prices). Once the body work is done on the dash it should look like it came that way from the factory (that's the goal).
The top hole is for the A/C controls which is a standard Vintage Air controller for thier newer generation systems. It's black like the rest of the dash items: gauges, radio, pedals, etc. The newer systems are electronically controlled instead of cable driven. I have a similar (just larger) system in my '69 Charger and it works great.
If you're REALLY interested I can post the part#'s we used for this system. It's not a bolt in but a little fab work and you've got something that should look like it belongs. We will have to modify the glove box though. It will still be there but not as deep.
Old 06-12-2012, 12:16 PM
Moe Craig's Avatar
The top hole is for the A/C controls which is a standard Vintage Air controller for their newer generation systems. It's black like the rest of the dash items: gauges, radio, pedals, etc. The newer systems are electronically controlled instead of cable driven. I have a similar (just larger) system in my '69 Charger and it works great.
Yah Bobby41909, Numbers would be great. I looked and tried the Gen IV Magnum mock-up part number 671450 to see if I could stuff it into my '49 f1. Are you going with the Gen II or Gen IV? Is it a Sure Fit Kit? Or did you piece it together?
Old 06-12-2012, 01:06 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Awesome build. I'll be following along.
Old 06-13-2012, 04:57 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
really nice work done right!
Always better to start with a solid example than a pile of iron lace curtains.
Old 06-13-2012, 10:16 PM
chappys4life's Avatar
chappys4life chappys4life is offline
chappys4life is starting off with a positive reputation.
I like your work but such a overdone color combo
  #28
Old 06-14-2012, 01:23 AM
Schuyles's Avatar
Schuyles Schuyles is offline
Schuyles has a great reputation on FTE.Schuyles has a great reputation on FTE.Schuyles has a great reputation on FTE.Schuyles has a great reputation on FTE.
Quote:
The only color I see is red wheels...
  #29
Old 06-14-2012, 08:22 AM
topmoo's Avatar
topmoo topmoo is online now
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Bobby, check with 51PanelMan. He has lots of parts for 48 - 52 and probably has the spears and the fender section.
Your build looks great!
Oops! didn't see the second page...
  #30
Old 06-14-2012, 10:30 AM
51PanelMan's Avatar
Thanks for the mention. Yes, Bob and I have been in communication.
My L8000 project proline69 Large Truck 14 02-17-2013 10:40 AM
t-case linkage >? limptera13 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 10-24-2010 12:41 PM
1979 Ford F150 4x4 build jmont004 1973 - 1979 F-100 & Larger F-Series Trucks 29 03-19-2010 09:06 AM
Engine Comparison Bobby Light 6.4L Power Stroke Diesel 45 03-23-2009 04:44 PM
Checking Oil "Short Stick" Method - FYI Bobby Light 6.4L Power Stroke Diesel 14 02-26-2009 09:05 PM
Tags
50s, 51, build, early, f1, ford, lowering, rod, street, truck, updates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
