'73 C706 steering shaft bearings
tried pulling the steering column, What I do see is that the lower section of the steering shaft and coupler has two u-joints with a double center yoke (C5TZ-3814-B) in between them.
A clamp yoke (D2HZ-3814-A) attaches to the lower steering shaft & coupler (where the lower u-joint is located), then attaches to the input shaft of the steering gearbox using a pinch bolt, two washers and a nut, the shaft & coupler won't fit through the base plate[hole in floor.....one more obstacle. will take a "saws all" to the floor and enlarge opening, unless other options are available
Southtarnation
12-20-2015 10:30 AM
4WD67F250
01-31-2004 02:15 PM
