How do I know my EGTs? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-13-2012, 09:54 AM
bama29fan's Avatar
bama29fan bama29fan is offline
bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.
Quote:
Originally Posted by Painted Horse View Post
You will see Oil temps hit 242 while towing up steep greades. The temps drops back off pretty fast as soon as you summit the grade. Someone asked one of the engineers a year ago and the answer was that was with in reason for this truck.
The Edge CTS will show all 4 EGT sensors. Its kinda of interesting to see what a regen does. 1st sensor my only be 700 but back sensor will hit 1200 So you know the system is pouring in extra fuel for the regen.
The Edge also allows you see the soot % so you have some idea of when a regen will take place, It displays a red "R" all during the regen, So you know the duration instead of just when it started. Not that it matters much. I've gotten to where I pretty much ignor regens anymore. They are just a non-event in my driving.
Did anyone ask the engineer about Trans Temps? Maximum, normal, etc?
I have seen my trans temp at 203 on the interstate unloaded. pulling my camper this past weekend it didnt go any higher than that and stayed in the mid 190's most of the time. but it seem that at a steady fast speed (interstate trips) the temp is 200 even unloaded. i havent towed on the interstate yet....that will come this weekend
  #32
Old 06-13-2012, 01:43 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
Remember that your transmission uses an oil-to-water cooler rather than the traditional oil-to-air coolers that older trucks use. This means that your transmission fluid is being brought closer to the temperature your coolant is at as it goes through the cooler; if the transmission fluid is cooler than your engine coolant it will be heated as it goes through the cooler. No cooling happens unless your transmission fluid is hotter than your engine coolant. Which happens to rest around 195 degrees when you're fully warmed up.
So it's going to stay around 200 most of the time. Loaded heavy or empty it's always going to be around there.
  #33
Old 06-13-2012, 01:58 PM
darren32's Avatar
darren32 darren32 is offline
darren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputation
Good info, thanks Tom!
  #34
Old 06-13-2012, 02:09 PM
bama29fan's Avatar
Cool!!! thanks
  #35
Old 06-17-2012, 06:58 PM
kabur66 kabur66 is offline
kabur66 is gaining momentum as a positive member of FTE.
Cool!!! thanks
I agree . . . good info. . .ken
  #36
Old 06-17-2012, 11:05 PM
srteach srteach is offline
srteach is gaining momentum as a positive member of FTE.srteach is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Greengas View Post
... I've got a big trip coming up and I know that one of the grades I will be facing is 10 degrees up hill (just outside of Jackson, Wy. Ron
That 10% (NOT 10 degrees) grade is outside of Wilson WY., and if the grade worries you, you can follow the river route, which is a flat run. If you are going into the Tetonia / Driggs area, the pass is the short route, but if you are going to Swan Valley or Idaho Falls areas, either way will suffice. Other than to say EGTs are good to know, Ill let those with more experience answer the actual question.
  #37
Old 06-20-2012, 10:10 PM
Greengas's Avatar
Greengas Greengas is offline
Greengas is starting off with a positive reputation.
Quote:
Thanks for the recommendation on alternative route. On the percent vs degree, well lets just say that math has never been my thing
  #38
Old 06-21-2012, 12:12 AM
You're welcome. Many people don't really understand the difference, but it is huge.
To follow the river run (a winding road along side the river) leave Jackson Hole southbound towards Hoback Junction and turn right toward Alpine Wyoming. When you get to Alpine, turn right. That highway (US26, IIRC), will take you through the Swan Valley area into Idaho Falls, my old stomping grounds. There are some grades, but they are shorter and more shallow climbs than the Wilson Grade.
  #39
Old 06-21-2012, 08:45 PM
GoCamping's Avatar
GoCamping GoCamping is offline
GoCamping is gaining momentum as a positive member of FTE.GoCamping is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by desertnomad View Post
Most of those RV folks who ask about your EGT's are the ones with 6.0L.
Or the 7.3L. I've only got a 40hp tow tune and I run out of EGT before I run out of pull going up these east coast "mountains"
  #40
Old 06-21-2012, 08:48 PM
GoCamping's Avatar
wow that's interesting, I always thought (from something I'd read awhile ago) that trans fluid temps over 175 shortens the life of the tranny or fluid ... guess I must be mistaken. What's the standard trans fill? (sorry don't mean to hijack...)
  #41
Old 06-21-2012, 10:56 PM
Tom's Avatar
Quote:
Yup. Standard trans fill is Mercon LV; both the 6R140 and it's predecessor the 5R110 have thermostats that maintain transmission temps to a relatively narrow range. The 5R110 thermostat opened at 170, and while I'm not sure the exact temp for the 6R140 the temps like to stay right around 200. I believe the higher temperature helps with increased transmission efficiency.
  #42
Old 03-09-2014, 11:59 PM
ia2004anderson ia2004anderson is offline
ia2004anderson is starting off with a positive reputation.
Quote:
Originally Posted by mrjc View Post
While I think ones trucks max transmission and oil temps are a personal pref. I like to keep my trans temp under 200 and oil under 210. Trans temp has never exceeded 197 yet, and oil stays around 205 at its highest, this while towing up a mountain pass for about 45 mins at 60 MPH and towing my 15K lb 5er. I go in altitude from 7100 FT to 10,000 Ft where the campsite is.
I just got the 2014 F-250 with the 6.7 L. I was driving on the highway today not pulling anything and a relatively flat road cruise set at 75. My trans temp was holding around 198 and would go up to 208 if I speed up to 85 to pass. Not sure if this is normal on the 2014 but it seems higher than what others on here have seen.
  #43
Old 03-10-2014, 02:53 PM
F stock owner F stock owner is offline
F stock owner is starting off with a positive reputation.
I'm not aware of any lubricity additive that is approved for 6.7L so what are you guys using?
To avoid any potential hassles from Ford saying I'm not using an approved additive I use PM22A from Ford. It all comes down to personal choice and what works for you. There are many threads about additives on this site and others. Here's one: Fuel Additives; which ones are okay with Ford to use? - Diesel Forum - TheDieselStop.com
Back to the EGT issue: I haven't seen anybody talk about cool down. Yeah, the truck will pretty much take care of it self. And yes, it's nice to know what's happening while you drive but one of my main reasons for getting an Edge CTS was to see what the EGT is when I stop. Pulling into a rest area from the interstate or especially after a long grade, I want to know what my EGT is so I can let the turbo cool down before shutting off the engine. I believe the turbo bearings are water cooled so you could argue that when everything stops the water will boil limiting the temps to 212. I still like to cool down to 300 before shutting down just in case the water boils away. The manual even says to idle a few minutes after a hard pull to allow the turbo to cool. Maybe I'm pampering my truck too much but I certainly don't want to coke my oil.
  #44
Old 08-12-2014, 11:50 PM
WABowHunter's Avatar
WABowHunter WABowHunter is offline
WABowHunter is starting off with a positive reputation.
What's the highest EGT 1 you've seen?
  #45
Old 08-13-2014, 05:57 PM
bama29fan's Avatar
Quote:
Not sure on the exact number but around the mid 900's pulling camper up a grade
First REGEN Observed tracyclifton 6.7L Power Stroke Diesel 6 07-01-2015 11:08 AM
Monthly GTG's Toyman Michigan Chapter 31 12-19-2014 02:30 PM
Using the 2015 truck for its maiden voyage tomorrow! ruschejj 6.7L Power Stroke Diesel 20 12-17-2014 06:39 PM
Ford Man in the Making! Tanner Jackson Southern Region 0 07-11-2014 03:51 PM
"Slick" featured in new movie wagonerkl 1961 - 1966 F-100 & Larger F-Series Trucks 5 02-24-2010 01:56 PM
Tags
2012, 5th, 62, connect, cts, edge, egt, f250, f350, gas, pull, reading, regen, swnsor, temp, wheel, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
