Truck sputters and dies - Ford Truck Enthusiasts Forums
Old 06-09-2012, 08:27 PM
Russronning Russronning is offline
Russronning is starting off with a positive reputation.
My truck will start, idle, run great, then after driving a few minutes, it dies like its out of fuel. Does this mostly between 30-40mph but has done it at higher speeds, never at a stop. Sometimes it will start right back up, sometimes it has to sit for a few minutes. Coil, fuel filters (both), spark plugs, wires, and distributor are new. Carb was rebuilt last weekend, but I did remove a spacer that was not the right size.
'82 f150, 302, 2150 motor craft carb
Old 06-09-2012, 09:31 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Welcome to FTE.
Quote:
Dies like it's out of fuel - in that it sputters for a second or two and then dies?
Check your fuel pressure & output rate at the carb.
Old 06-09-2012, 10:10 PM
It will lose power and decelerate then just die. It happens randomly but increasingly do today. At one point I was able to control it by letting of the gas pedal when it started to sputter then accelerating again over and over until I was able to get off the highway and turn it off. I'm brand new to fixing trucks as I bought this truck to be my introduction to it, I'll have to look up how to do those things you suggested but I appreciate the help greatly.
Old 06-09-2012, 10:49 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Have you checked the rubber fuel lines? I've had one 82 and two 81's, all of which had bad, rotten fuel hose. So bad that some of them oozed gas right through the side of the hose, and also allowed air to get in, and the air kept the fuel pump from supplying enough gas to run the truck very fast or very long. There's a hose on top of the tank and one from the hard line to the inlet of the pump. And, if you have dual tanks there are hoses from the hard line to the valve.
If you do replace the hoses get the new fuel line that is good to use with ethanol. I think the lettering on it is green, but I'm not sure. Anyway, I think it is time and ethanol that has killed our hoses, but I've sure seen a bunch of bad ones.
Old 06-09-2012, 11:06 PM
I do have a dual tank, and I'll be sure to check that in the morning Gary. I haven't seen any fuel leaking anywhere but then again I just realized the fuel pump is on the engine. (Thanks for showing me just how little I know Haynes Manual) I did notice that the inline fuel filter (that is clear) wasn't getting any fuel in it after it died, but it did start right up after sitting a while and the filter would fill right up.
Old 06-09-2012, 11:17 PM
Gary Lewis's Avatar
You said you've replaced both filters. Where is the other one? I run two clear filters - one ahead of the pump in place of the tank selector valve and one between the pump and the carb. The first one protects the pump, and on trucks that have sat quite a bit usually has to be changed frequently as it catches a lot of rusty silt.
If you need to replace the hose on top of the tank, and I'd bet you will, there is usually enough length on the bolts holding the tank on via the straps to let you get to the hose w/o taking the tank out. And, make sure that all of your connections are tight as any leak ahead of the pump kills it's ability to pump.
If the hoses don't seem bad it may be the pump. Chris is right on with his suggestion to check pressure and volume, and from what you've said it does sound like a fuel problem.
Old 06-09-2012, 11:29 PM
The clear one between the pump and carb and a cartridge that screws into the carb itself. So did you just remove the tank selector valve with a filter? Or add one in addition to the valve.
Old 06-09-2012, 11:40 PM
Gary Lewis's Avatar
If the cartridge you refer to is the standard one and not a really high-dollar special one it is almost good enough to catch gnats, but nothing smaller. I've taken the apart and even the Motorcraft/Autolite ones are nothing but a screen. The paper filters have much better filtering capacity. MUCH better.
I took the tank selector valve off and replaced it with a clear filter connected to the front tank. I don't use the back tank so don't need the valve.
Old 06-09-2012, 11:50 PM
That's actually a great idea, I think I'll do that while I'm looking for fuel line leaks.
Old 06-10-2012, 11:50 AM
Lines looked like the PO recently replaced them. I'm going to get the stuff to check the pressure after church.
Old 06-11-2012, 10:25 PM
Finally got under the truck again, fully expecting to change the fuel pump and I noticed a small drip where the fuel line met the pump. Tightened it up, and now it's running good, well other than bogging down when I go over 60mph, but that's another post. Thanks for your help guys!
Old 06-12-2012, 12:08 AM
Gary Lewis's Avatar
That's what I was talking about. Any leak at that point lets air into the system and kills the pump's suction. Well done. Now, on to the next problem.
Truck will not stay running in th cold Samuel Poynter 1987 - 1996 F150 & Larger F-Series Trucks 14 01-16-2017 11:23 AM
Truck dying after warming up TylerMcDonald 1967 - 1972 F-100 & Larger F-Series Trucks 41 04-23-2015 11:32 PM
Weird problem twise 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-20-2014 07:02 PM
1990 Bronco 351 puzzling me vandal956 1978 - 1996 Big Bronco 24 06-07-2012 02:53 PM
My truck dies when iI turn right ctaylor57 f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 63 09-18-2011 10:14 AM
Tags
1999, 360, carbureted, died, dies, expedition, f150, ford, minutes, run, running, sputtering, sputters, stopped, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
