Who says a 2wd Van can't go offroad?
if you think you've got it good now, just try it with my locking diff
the only real limiting factor to off-roading my van is that i don't want to beat up the toolboxes with all that abuse.
but you should have seen some of the places i took the LTD i used to have... and some of the dents i put on the underbody
I seem to recall falling into a Culvert not all that long ago .
It gets worse now, i have a front hitch receiver, a warn winch that fits in it, and an Eaton E-locker. I expect much trouble in the future. At least I have the winch to pull my own dumb self out.
I can give you some warning, not everywhere that you get stuck, you'll find a sufficient anchor point to secure your winch to pull yourself out, and not every stuck can be extracted by a straight line pull from either direction, never go out alone. I wheeled everything from rough construction sites to mountains, I don't care your experience, or equipment, never go alone, you'd not believe the stuff I've either witnessed, or got myself in.
well if you do go alone... carry something like this, could save your ***.
Smittybilt Products Winch Anchor Support Platform
Most places east of the Mississippi where one would get stuck will have a reasonable anchor point nearby. Two things that are needed to take advantage of these are a long length or wire and a ****** block. Used with the winch, shackles and tree straps that everyone also carries, will get a rig out of stuck spots most times. The long wire does not need to be at the maximum strength point. I would recommend 250 feet of Amsteel Blue 1/4". It has a breaking strength of 8600 lb and the whole coil will only weigh three pounds. Add this to your 125 foot winch cable and you can find a tree or a big rock somewhere. Redirect vectors with the ****** block.
Having said this, I confess that I NEVER go off roading alone. Always two rigs.
Here is a link to everything you will ever need to know about off road recovery:
http://www.pirate4x4.com/tech/billavista/Recovery/
