15w40 in a V10 Triton Excursion?! - Ford Truck Enthusiasts Forums
Old 06-09-2012, 06:18 PM
pdxamir pdxamir is offline
pdxamir is starting off with a positive reputation.
So my father in law has a 2000 Ford Excursion v10 Triton engine(Gas FYI)
I love driving this truck when I can, and its a beauty.
However, I recently learned from my father in law that he put 15w40 in his engine. Only reason i found out is that I was going to change its oil with 5w20 when he told me he used 15w40 in the last change. "The guy" told him it would be ok since that is what he had at the time.
Is it me, or does that number scare me for some reason? Im still going to change the oil tonight, but I want to know should I be worried about some other stuff besides the oil since he put 15w40 in it? I shouldnt stick with it, should i?
Should I be worried about internal damage of any sort? I have not noticed anything different since he has had that oil in there for about two months.
Old 06-09-2012, 06:33 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
A high mile motor in, I hope, hot weather? Probably ok.
The low tension rings aren't going to like the thicker oil, especially on cold starts. You get an oil burner on cold starts, eventually leading to an oil burner all the time as the rings are "abused" on every start up.
That's my theory, based on a little fact.
I'd go back to the recommended oil and stay there. We have a 100,000 mile Lexus and a 95,000 mile Exploder running 5w-20 in blazing hot So Cal--no oil use in either one of them.
Old 06-09-2012, 06:43 PM
We live in Vancouver Washington... Gets a little cold in the winter. Summers are hot.
Anyways, should I have to worry about any internal damage? Also, when i change the oil, should i notice a little performance improvement?
Old 06-09-2012, 07:02 PM
If you had damage, you'd have a noise or a blue cloud or both by now.
You might pick up a tiny bit of mpg with the thinner oil, "performance" wise, I don't think it's going to shave a tenth off the quarter mile time....
Old 06-09-2012, 07:39 PM
Opossum Opossum is offline
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
Why on earth would you put 5w-20 in any of those engines, 0w-30 yeah, I sure hope you keep a REALLY good eye on your oil pressure.
I could see a ever sooo slight possible increase in MPG but WAYYYY shorter engine life.
Old 06-09-2012, 08:00 PM
Old 06-09-2012, 08:02 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
5W-20 is what ford calls(take a look in the owners manual) for in the 6.8 and 5.4's. thats all i run, from -30F to 80+F it works great w/no issues.
Old 06-09-2012, 08:10 PM
I don't work on much "new" stuff, so if it's what they recomend factory in later years then yeah. In which case I'd personally see if I could search out a 0w20, But I would never put a 20 in a motor that when new wanted a 30, and I'll always go for the lowest W(first) number I can get my greasy hands on.
Old 06-09-2012, 08:22 PM
Old 06-09-2012, 09:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Ford spends millions developing the engine, including the proper oil for it. Backyard mechanics, with ZERO testing, and just about that amount of knowledge, come up with a better solution for what oil to run. I just don't understand. I never will.
Old 06-09-2012, 09:39 PM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
When I seetviced police fleets even in blazing hot summer weather at 90+ degrees outside with idle times of 8 hours+. I know is not a v10 or a 5.4 it's a 4.6. A 5.4 is pretty much a bigger 4.6, a v10 is just a 5.4 with 2 cylenders added at the rear. So that being said that ford modular motors will turn 300,000 miles usually on that " water" oil. I think ford spent enough on developing the motor With strict tolerances in mind. Also the cam followers are oil pressure driven. If you read the back of the jug of 15 40 it says " not for use in gasoline engines equipped with a catalyst" so pretty much every gas motor. 5-20 and 5-30 has been proven that there is no lesser protection with 5-20.
Old 06-09-2012, 10:57 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
Exactly what I was thinking. I have never heard so many myths and assumptions until I got into the mechanic field. ............seriously
Old 06-10-2012, 04:40 PM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
Exactly - I have a guy who comes into the shop every summer on his vacation and tries to insist I put Rotella 15w40 into his 2008 Pontiac G6!! Give me a break - I refused and turns out he uses it because he gets it for free since he handles fleet service for his company. He's just asking for trouble when the car needs 5w30. There are some older and higher mileage vehicles I switch to 5w30 vs. 5w20 after talking to the owners to reduce some consumption but certainly not recommended unless you have an issue.
Old 06-17-2012, 12:39 AM
BigBlackX BigBlackX is offline
BigBlackX is starting off with a positive reputation.
We had most of our 5.4 and 6.8 trucks in our fleet rattling like heck on startup when I first started working at the phone company. I asked the senior tech what oil he ordered for our bulk tank, and he said "10w40, heavier the better for these junk motors!". We switched to 5w-30 and all of a sudden the rattling just about ceased. I, myself, run motorcraft 5w-20 semi-synthetic, I get it at autozone for as cheap as conventional oil. My v10 loves it. The 6.0 chevy ls motors clack and rattle if you put heavy oil in them also, I "fixed" a buddys chevy truck draining out the rotella 15-40 and putting in 5w-30. His truck was really sluggish from the computer backing the timing out cause it was hearing detonation, which was actually rattling from the too thick oil in the lifters.
5w-40 Oil in a not-so-cold climate? dlragalie 1999 - 2003 7.3L Power Stroke Diesel 71 11-02-2016 05:35 AM
66 Ford F100 w/352, oil weight and pressure help please jasindude1 1961 - 1966 F-100 & Larger F-Series Trucks 9 04-16-2016 03:54 PM
Just need to vent a little...... 2civicrr 6.7L Power Stroke Diesel 22 12-14-2015 10:31 AM
Experiences with stuck engines and how to bring them back to life dasbulliwagen 1957 - 1960 F100 & Larger F-Series Trucks 5 09-02-2015 12:00 AM
Newbie Diesel Owner('s Friend) '06 F250 6.0 Randall's Truck 6.0L Power Stroke Diesel 9 01-20-2014 03:13 PM
Tags
15, 15w40, 40, 54, excursion, expedition, ford, forum, mile, oil, put, quarter, run, time, triton, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
