1999 Ranger 4x4 problems
Old 06-09-2012, 04:15 PM
Saminy's Avatar
Saminy
Saminy is offline
I have a 99Ranger with 4 wheel drive problems. I bought the truck used and was told the transfer case motor was shot. The motor was replaced with a brand new one, we have swapped both the dashboard switch and the GEM with known good ones. The only thing left (I think) is the PVH solenoid, which we haven't swapped as we have been unable to find one other than a stealership. We did something that caused it to shift into 4 wheel high, but then could not get it out. Pulled the hubs--they looked fine--unlocked them manually and put them back on, however the transfer case is still in 4 wheel. The 4 wheel indicators on my dash are flashing a "six" code. Checking voltage on the PVH solenoid there is continous voltage on the center pin and there is vacuum to the solenoid but nothin out. The other two pins are supposedly lock/unlock grounds. Does the ground come through GEM? Bad solenoid?
Old 06-10-2012, 08:43 PM
pawpaw's Avatar
pawpaw
pawpaw is online now
Welcome to FTE.
I don't know squat about the 4X4 electricals & see you don't have any replies, so if no responses here, try the drive line forum, bet they know, or know where you can find the answer. Clutch, Transmission, Differential, Axle & Transfer Case - Ford Truck Enthusiasts Forums
Let us know how it goes.
Scottybronco
2004 - 2008 F150
03-16-2017 10:01 AM
ddt4812
02-09-2012 11:32 PM
mhbtfb
2004 - 2008 F150
12-21-2009 05:18 PM
rickerho
1999 to 2016 Super Duty
16
08-05-2007 08:45 PM
Quick Reply: 1999 Ranger 4x4 problems
