Banks IQ 6 Gunn Questions - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 06-09-2012, 03:02 PM
Gcapell Gcapell is offline
Gcapell is starting off with a positive reputation.
I have 2008 F350 crew cab 6.4 and recently purchased the Banks IQ and 6 Gunn tuner. I'm very new to diesels. Can anyone give me some advice on which settings will improve gas mileage cause honestly I'm not seeing it yet. Is it even supposed to be a noticeable difference. Thanks.
Old 06-09-2012, 10:56 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.4L Powerstroke Diesel forum.
Old 06-09-2012, 11:50 PM
auriferous auriferous is offline
auriferous is gaining momentum as a positive member of FTE.
Quote:
there is of course the econ mode,the mech at banks in azusa said to try it on the 4 setting and see how the mpg's are so I have been running that for a few months and can't really tell. Since I had it installed I have definitely seen a 2 mpg gain combined driving and I chose to tow one way on econ and returned home on the 4 setting, it seemed to get going better on 4 [my trailer is about 6500 lbs] good luck and welcome! [I hand calc my mileage as some tuners cause the readout to lie,mine however has been accurate ]
Old 06-10-2012, 11:34 AM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
I'm sure Senix will be able to chime in here.
All trucks are different as the way their driven. Some people don't see a noticeable increase in MPG's after tuning, and some allegedly see 2-4 MPG's. You'll honestly have to test different settings. The real benefit of the banks that I saw was the decreased regen frequency with improved performance.
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I run mine on level two all the time. about 1.5-2 mpgs.
Biggest improvement is regens being farther apart.
I tow in level 2 with anthything less then 10K and over that I tow in stock.
Old 06-11-2012, 04:52 PM
smotrs's Avatar
smotrs smotrs is offline
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
That will be your number 1 benefit is that regens will be further apart compared to stock. Otherwise, don't expect more then 1-3mpg increase on the various settings. You also won't have to remove it for smog inspections either if required in your state.
Old 04-23-2014, 07:44 PM
Quote:
I just posted on another thread about towing on the econ setting and
found this thread ! I won't be towing anything on a setting this high again ! was warned about the risks of damage and will be staying in the stock or #2/econ mode strictly.
Canadian Banks IQ for DPF Delete Available??? turbinefix 6.4L Power Stroke Diesel 0 01-12-2016 10:52 AM
BANKS IQ Question olbattlebuggy Computer Chips & Tuners 1 02-18-2013 04:13 PM
Banks IQ and Ford Warranty jtaylor1920 Computer Chips & Tuners 8 07-13-2012 03:11 PM
New to Diesel Trucks- Maintenance ?s Gcapell 6.4L Power Stroke Diesel 7 06-19-2012 07:32 AM
banks 6 gun with IQ tuner highteckredneck Computer Chips & Tuners 21 02-08-2012 12:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
