Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1966 F-100 & Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
  #1 (permalink)
Old 06-09-2012, 10:29 AM
gangstakr's Avatar
gangstakr gangstakr is offline
Garage is empty, add now
gangstakr has a great reputation on FTE.gangstakr has a great reputation on FTE.gangstakr has a great reputation on FTE.gangstakr has a great reputation on FTE.
Temperature gauge sending unit and OHM's
I searched all through the electrical forum no clear answer. So now I will ask all of you and see if I can get a good answer.
My cooling system has irritaded the hell out of me for some time. Here's what I have done so far.
Replaced water pump about four years ago, it was leaking.
Replaced radiator with a bigger one.
replace temperature gauge with an NOS one that NumberDummy located for me.
Replaced sending unit.
All new hoses and coolant.
Here's the situation, When my temperature gauge starts reading 220 then gets close to 230 (after 230 I think it self destructs) I would pull over and let it cool down before prceeding on my journey. This only happens in So.Cal. rush hour traffic in the summer months.
I met up with the owners of "The Fan-Man" regarding electrical fans being installed. Their fans, when installed properly automatically come on at 195 degrees and cut off at 182 degrees.
My truck was checked and rechecked regarding temperature.
Scary situation watching my gauge climb to 220 then approaching 230. When the needle was on the "2" of 230 my actual temperature was 195 and the fans kicked on at the "0" of 220 the fans shut off.
Ater checking everything out thoroughly, it was determined I'm getting a bad reading on the gauge. (obviously)
So here's the question. How do you know if the sending unit and gauge are compatible? What OHMS should the be reading? If my gauge is reading high how do I get it to read correctly?
__________________
Staying low for now
64 lowered longbed
Robert
  #2 (permalink)
Old 06-09-2012, 12:55 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Install a Stewart Warner (or similar) direct reading temp gauge and be done with it. FoMoCo gauges were never very accurate, could vary wildly from one like vehicle to another.
The temp needle on my '65 never went past the half way point throughout all the years I owned it (1965/2009)
Besides driving on the worlds longest parking lot on a regular basis, the hated 405 fwy, I drove up to Jawbone Canyon in the Mohave Desert at least once a month to go target shooting. Today, it's reserve for the desert tortoise, no shooting allowed.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 06-09-2012, 01:17 PM
gangstakr's Avatar
Can you find me the correct temp sending unit? I will not put in a stewart warner gauge
__________________
Staying low for now
64 lowered longbed
Robert
  #4 (permalink)
Old 06-09-2012, 01:44 PM
Ford Parts Guru
2013 Ford Escape
Quote:
We've had this conversation before, a couple of times. Once on the 'Ameche' .. once here on FTE.
I told you that there's an insert that threads into the head, then the sending unit threads into it. Did you replace the insert, or is it still in place? I don't recall what you said.
Why not install a direct reading gauge? You installed the bucket seats you got from that 1968 Ranger, the steering wheel it has, would come in handy in a gang fight.
You cannot drive no more than 2 MPH over speed bumps. The parking lamps are hidden from view...even if you passed out maps to their location, I doubt some peeps could find them, so your truck is faaar from original.
__________________
  #5 (permalink)
Old 06-09-2012, 02:18 PM
gangstakr's Avatar
It does not matter what my truck is far from, IT'S WHAT I WANT!!!
If your not going to be of any help, step back!! I know what our conversations were about, as you can tell, nothing was resolved. Through trial and error I'll make it work like, I WANT IT TO!
For anyone else out there reading this post,
What is the OHM reading for sending unit? What is the OHM reading for Original gauge?
__________________
Staying low for now
64 lowered longbed
Robert
  #6 (permalink)
Old 06-09-2012, 03:37 PM
Ford Parts Guru
2013 Ford Escape
You ragged on me a coupla days ago, didn't bother me a bit, because I'm battle hardened. Now I rag on you and you have a temper tantrum.
I don't know what the ohms are, cuz the parts catalog doesn't say. Do you the truck shop manual? Prolly not, so where else will you get the info?
__________________
  #7 (permalink)
Old 06-09-2012, 04:19 PM
gangstakr's Avatar
Battled hardened, my ****. You cry like a little girl when you don't get your way. Your upset about the 68 mustang seats (that were never going to be yours in the first place) You've brought them up in each post I've started. so now you want to take your toys (books) out of the sand box and go home. Well go, I'll still find my answer I just started here because of the knowledge here.
__________________
Staying low for now
64 lowered longbed
Robert
  #8 (permalink)
Old 06-09-2012, 05:45 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Robert.
Here are the trouble shooting guides form the shop manual.
Loose or Broken Wire from the CV to the Gauge.
Defective Gauge
Defective CV
defective radio Suppression Choke. (What the F this would have to do with it i dunno)
Test Procedure go for the gauge is run to operation and physically check the temperature of the coolant and compare to the gauge.
If the Gauge indicates within the normal section it is working correctly even if it is 20 degrees off.
There are no Ohms reading for the Temp Gauge. It should read 5 volts average while operating.
ohms for cold on the sender is 75.
ohms for full hot is 10.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #9 (permalink)
Old 06-09-2012, 06:24 PM
gangstakr's Avatar
Quote:
Originally Posted by garbz2 View Post
Robert.
Defective Gauge
Defective CV
Garbz
Thank you Sir. My truck will stay cool now. I do want to get the gauge working as close as possible, but no chrisis.
__________________
Staying low for now
64 lowered longbed
Robert
  #10 (permalink)
Old 06-09-2012, 06:38 PM
gangstakr's Avatar
I know it will stay cool now while in rush hour traffic thanks to these two 12" fans.
Click the image to open in full size.
I just want to get the original gauge working properly. I do know what it's reading when the fans kick on I also know what it's suppose to be reading. Now I just want it all to match. But I'm COOL with it now.
__________________
Staying low for now
64 lowered longbed
Robert
  #11 (permalink)
Old 06-09-2012, 08:57 PM
KO1960 KO1960 is offline
1965 Ford F-250
KO1960 is starting off with a positive reputation.
What about getting the gauge rebuilt? I saw a recent article on a company called Classic Instruments that will rebuild existing gauges with modern movements. Not cheap, I'll bet. Good luck.
Kurt
__________________
Plumber by trade-mechanic by weekend
1965 F250 Camper Special w/ 390
  #12 (permalink)
Old 06-09-2012, 09:51 PM
gangstakr's Avatar
Quote:
Kurt
There's no doubt in my mind that the gauge is good. The gauge works and was NOS up until a couple of months ago when I installed it. The sending unit is new but can be the culprit. Depending on OHM's I know I can put a resistor between the sending unit and gauge to bring it down to the temperature when the fan kicks on or when the thermostat opens. But doing this only makes it accurate for the sending unit on the fans. I'm not sure if this will give me accurate readings at any other time. So a proper sending unit for the gauge is my goal.
__________________
Staying low for now
64 lowered longbed
Robert
  #13 (permalink)
Old 06-10-2012, 12:08 AM
Ford Parts Guru
2013 Ford Escape
C1TF-10883-C .. Instrument Cluster Temperature Gauge-Use with Round Speedometer / Obsolete / 29 available NOS
Last MSRP: $69.40 / Dealer net cost: $41.64.
Applications: 1961/66 F100/1100 / 1963/69 N/NT/T500/1000 / 1967/69 F800/1000.
C3TZ-10884-A .. Water Temperature Sending Unit (Motorcraft SW-391) / Obsolete / 384 available NOS
No prices listed on Ford Dealer Parts Locator System.
Applications: All gasoline 1961/64 I-6 & V8 Trucks except Econoline (no V8) & P Series Parcel Delivery / 1965/66 F500/750 w/FT engines / 1965/66 F100/750 240/300 I-6 / And etc.
Some of the above: The sending unit threads into an insert in the cylinder head, there are two different types. One type is pressed into the head, the other type threads into the head.
__________________
Tags
100240f, 1965, 2006, bad, bwd, escape, ford, hybrid, mustang, ohms, sender, sending, signs, temp, temperature, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
