AOD to C6 Swap? - Ford Truck Enthusiasts Forums
AOD to C6 Swap?
Old 09-29-2002, 09:16 AM
frank_65 frank_65 is offline
frank_65 is starting off with a positive reputation.
AOD to C6 Swap?
Have an 87 E150 van with 302EFI & AOD. Tranny is bad. I have a C6. How much trouble would it be to swap in the C6? Will drive fit and what about mounts are they the same? Appreciate any help, advise, comments. Thanks.
Old 10-02-2002, 12:44 PM
DoubleA DoubleA is offline
DoubleA is starting off with a positive reputation.
AOD to C6 Swap?
I just changed out a friends 85 F150 from AOD to C6.
The flywheels are different, I guess the center hub is different.
The shift linkage is different, the AOD lever points up and the C6 points down.
need vacuum line to modulator, and the kick down linkage.
Mounts up the same (within a 1/2")
He had the c6 in the truck, put in the AOD, I sold him my truck and we swapped the trannys back out so I had the AOD. We never changed the flywheel but they are different.
Hope this helps
Old 10-02-2002, 01:08 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
gasman6674 is gaining momentum as a positive member of FTE.
AOD to C6 Swap?
1982 C6 swap to 1985 AOD? miashley150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 03-18-2013 06:40 PM
C6 to AOD Swap dreadinger Clutch, Transmission, Differential, Axle & Transfer Case 3 06-20-2008 08:54 PM
AOD in 68 with 302? atcaw94 1967 - 1972 F-100 & Larger F-Series Trucks 11 05-08-2007 03:09 PM
AOD Vs. C6 MetallicaFan39 Clutch, Transmission, Differential, Axle & Transfer Case 7 03-23-2004 10:35 AM
C6 To Aod Swap? nechun 1978 - 1996 Big Bronco 7 12-03-2003 09:13 PM
Tags
1978, 1999, aod, bronco, c6, explorer, ford, mounts, swap, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
