F250 rear brake R&R help - Ford Truck Enthusiasts Forums
Old 06-09-2012, 10:21 AM
vwfreak's Avatar
vwfreak vwfreak is offline
vwfreak is gaining momentum as a positive member of FTE.vwfreak is gaining momentum as a positive member of FTE.
Can someone steer me to an existing thread on replacing rear brakes? I've done a ton of half ton brakes but never any 3/4 ton brakes and am wondering what I am getting myself into... I pulled wheels and started pulling hubs... Axle is loose but before I go any further what the heck am I getting myself into....?
Old 06-09-2012, 05:24 PM
MyFordParts MyFordParts is offline
MyFordParts is starting off with a positive reputation.
Old 06-09-2012, 06:34 PM
vwfreak's Avatar
Quote:
Originally Posted by MyFordParts View Post
Thanks. Was looking for rear brake help though....
Old 06-10-2012, 04:30 AM
Alex from GA Alex from GA is offline
Alex from GA is starting off with a positive reputation.
1. Pull axle 2. remove bearing nuts and lock keepers 3. remove drum and take pictures of how everything goes 4. replace everything 5. put it back together 6. it's a PIA. I just did mine.
Old 06-10-2012, 09:47 AM
vwfreak's Avatar
Quote:
I took the passenger side apart but stopped short of removing shoes etc.. Will see what this will cost to have a shop do it. If it's not prohobitively expensive they'll get this job....
Need help - 1957 2 ton questions ireding Large Truck 7 03-21-2013 11:31 PM
brake control ideas navyfordman 1999 to 2016 Super Duty 13 02-26-2009 08:44 PM
Wheel wiggle onestrangebroncoII Offroad & 4x4 11 09-24-2004 06:34 PM
Trac-lok conversion question johnrebbb Clutch, Transmission, Differential, Axle & Transfer Case 0 12-03-2003 07:44 PM
headers for a 79 f100 with a 400 strseantrent Exhaust Systems 1 11-11-2002 03:14 PM
Tags
1977, 34, brakes, change, cost, denver, f250, ford, pictures, rear, replace, ton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
