Integrated Brake Controller weak? - Ford Truck Enthusiasts Forums
Old 06-09-2012, 03:34 AM
vectrex's Avatar
vectrex vectrex is offline
vectrex is gaining momentum as a positive member of FTE.
I recently picked up a used 29' 2005 Gear Box Toy Hauler. The unloaded vehicle weight on it is listed as 7658 lbs. I hitched this to my 2005 F-250 6.0, which has the integrated brake controller. I fired up the truck, cranked the brake controller gain up to max (10), put the truck in drive, fully activated the manual control on the brake controller, and took my foot off the brake. The truck was able to creep at idle with the trailer attached.
To isolate whether it was my controller or the trailer, they jacked up one side of the trailer, spun the wheel, and activated the trailer brakes with a test box they use at the dealership. They were able to successfully lock up the brakes on each wheel, each side with this. When we tried the same test with my trucks integrated controller, it stopped the wheels at a much slower rate and didn't lock them up completely. The tech mentioned that he was only seeing ~5 amps from the integrated controller which wasn't substantial. He was able to sense the current change as I actuated the controller, so it was working.
My questions are:
Is there any known problem with the integrated brake controller on the Super Duty's? Any way to further test it?
Any way to boost the current going to the trailer?
If I had to install a third party controller in my truck, is it a huge issue since I already have a controller hard wired in?
Any help appreciated.
-Eric
Old 06-09-2012, 03:51 AM
vectrex's Avatar
Of course, 2 minutes after posting this, I ran across this PDF which might explain it:
http://www.cvsa.org/programs/documen...2001-04-05.pdf
Have to do another test between 15-25 mph
Old 06-09-2012, 04:01 AM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
You beat me to it with your PDF.
Two thoughts here, mine of course.
First, in my opinion, reading how Ford's built-in controller operates should be mandatory reading before anyone is allowed to hook trailer to truck.
Secondly, of all the components in the trailer braking systems, all controllers, built-in and after-market, are the most reliable and the most often replaced unnecessarily. The liability issue for manufacturers of these things is huge and liability is probably taken more seriously by manufacturers than all other factors combined.
My two cents worth,
Steve
Old 06-09-2012, 08:18 AM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
That's good read, maybe we could get a mod to sticky it or add it to an FAQ.
Old 06-09-2012, 08:42 AM
RV_Tech's Avatar
Quote:
That would be an excellent idea. The question is continual and I have referred several folks to that same piece in the past. It is widely available on the Internet and I am not sure why there seems to be so little exposure to it.
Steve
Old 06-09-2012, 09:59 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
I'll add it to the tips folder as soon as I get back to my computer.
Old 06-09-2012, 10:50 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
This was ONLY on the '05 MY from my readings. They "fixed" it on the 06MY. 5th wheelers complained that they couldn't check the hook-up as the brakes wouldn't hold. When you take off, when you hear the auto door locks lock, the brakes are also energized.
I check mine by pulling the break-away lanyard then reinsert it as soon as I know I'm solidly hooked to the trailer. Don't leave it disconnected long, you may burn thru a wire.
Old 06-09-2012, 11:11 AM
vectrex's Avatar
The problem is, the information isn't in the manual. The first thing I did was to break out the manual and read about the brake controller operation. I'll have to go back over it next time I'm in the truck, but I don't recall reading anything about the 'smart' nature of the controller. I can understand the logic behind it, but for those of us used to third party controllers, it's an unexpected behavior. Glad to see it's not going to mean a controller replacement.
Old 06-09-2012, 11:20 AM
BPofMD's Avatar
Posting Legend
You're right...not being in the manual caused a LOT of people complaining to Ford about the controller not holding at 0 MPH. Part two was they also wouldn't replace their mistake with a recall. It can be fixed by replacing the controller with the newer model. From what I understand, removing one from a junked truck will work - direct swap. I didn't try it tho - at least not YET!
Old 06-10-2012, 08:06 AM
Fulltimer50's Avatar
Fulltimer50 Fulltimer50 is offline
Fulltimer50 is starting off with a positive reputation.
Still does the same thing with a 2011. For me I like the feature of no brake at stop. That way my trailer brake pump doesnt run when stopped at a light.
Old 06-10-2012, 08:58 AM
RV_Tech's Avatar
I often wonder if any device has ever been introduced that has generated as much confusion as Ford's IBC. When initially introduced it was roundly criticized by owners for making movement mandatory to test manual activation. Ford corrected that, but offered owners little in the way of instructions as to operation or troubleshooting. In addition, Ford's IBC offered few of the diagnostic functions found in the best aftermarket controllers.
If one Goggles Ford IBC, the confusion owners have suggests at least a device few would regard as "user friendly" or "intuitive". I have a hard time believing all owners of IBCs are idiots and am of the opinion Ford still misses the boat with this component by failing to provide owners with adequate instruction. It just is not supposed to be this hard!!
My opinion,
Steve
Old 06-10-2012, 11:49 AM
BPofMD's Avatar
Posting Legend
Quote:
Something new to me.... what's a "trailer brake pump" ?
It would be great if there is any Ford tech that does understand the TBC on our trucks to please do an article here on its operation and any differences between the different model years!
Thanks in advance!
Old 06-10-2012, 11:58 AM
RV_Tech's Avatar
Thanks in advance!
electric over hydraulic I believe is what he is referring to.
Steve
Old 06-11-2012, 11:22 AM
I've added the link to the bulletin to the Tips Folder.
Thanks for the heads-up guys!
Old 06-11-2012, 01:30 PM
BPofMD's Avatar
Posting Legend
Looks good...thanks John.
2008 integrated brake controller Angry_Clown Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 5 09-12-2016 10:14 AM
Electronic Brake Controller Question littleapple 1999 to 2016 Super Duty 7 02-05-2016 12:08 PM
man, I hate these kinds of service calls RV_Tech Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 34 08-29-2015 05:29 PM
2008 F450 no Trailer Brakes with brake pedal Arnie-Man Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 24 05-23-2015 11:45 AM
Brake Controller or Trailer Brakes? Great Danes 6.7L Power Stroke Diesel 78 11-14-2013 10:25 PM
Tags
blue, brake, built, codes, controler, controller, f150, f250, factory, ford, function, integrated, power, problem, weak, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
