HELP TRUCK WONT START
Old 06-08-2012, 08:51 PM
Mamma Bear's Avatar
Mamma Bear
Mamma Bear is offline
help my truck wont start it just clicks have no idea whats wrong started fine earlier now it wont
Old 06-08-2012, 08:58 PM
Opossum's Avatar
Opossum
Opossum is offline
Do the headlights work? Are they bright?
Old 06-08-2012, 09:04 PM
Mamma Bear's Avatar
Mamma Bear
the lights are dim
Old 06-08-2012, 09:07 PM
Opossum's Avatar
Opossum
Opossum is offline
Originally Posted by Mamma Bear
the lights are dim
Are you alone, can you get a jump start?
Old 06-08-2012, 09:08 PM
Mamma Bear's Avatar
Mamma Bear
ok will try ty
Old 06-08-2012, 09:14 PM
Mamma Bear's Avatar
Mamma Bear
truck started ty so much
Old 06-08-2012, 09:15 PM
ri_truck_guy's Avatar
ri_truck_guy
ri_truck_guy is offline
Welcome to the site.
Check to make sure your battery cables are clean and tight on both ends, If the cables check out, these trucks are notorious for the starter solenoid checking out. It's a relatively inexpensive part that sits on the passenger side inner fender just behind the battery. Make it's bolted tightly to the firewall as that's how the solenoid grounds. If uthe grounds are ok you can jump the solenoid by removing the red/light blue wire from the small post on the solenoid and applying 12V+ to the small post. If the engine turns over, replace the solenoid.
Old 06-08-2012, 09:17 PM
Opossum's Avatar
Opossum
Opossum is offline
Your welcome but your not done yet
Old 06-08-2012, 09:26 PM
Mamma Bear's Avatar
Mamma Bear
you totally lost me on that one
Old 06-08-2012, 09:27 PM
Opossum's Avatar
Opossum
Opossum is offline
Battery cables are good, of course check that.
Old 06-08-2012, 09:28 PM
ri_truck_guy
Sorry. It might make more sense if you print the post and read it line by line as you're looking under the hood.
Old 06-08-2012, 09:31 PM
Opossum's Avatar
Opossum
Opossum is offline
It will never make total sense cause it's wrong.
Old 06-08-2012, 09:32 PM
ri_truck_guy
However I don't have the truck in front of me but she said it clicked, so that click %99 is the solenoid, and if it's clicking it's working. And jumping the solenoid like that will CONFIRM that it works, NOT that it doesn't. Jumping the big posts with jumper cables if it turns over will tell you that it doesn't.
It won't hurt anything to check things. I can't tell you how many times I've seen a loose, poorly grounded solenoid click but not start.
Old 06-08-2012, 09:33 PM
ri_truck_guy
Sorry your holiness,,,,
Mamma Bear's Avatar
Mamma Bear
ok you guys are confusing me...lol
Quick Reply: HELP TRUCK WONT START
