1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
fuel pump/ relay
Old 06-08-2012, 07:00 PM
99f250craig's Avatar
99f250craig
99f250craig is offline
fuel pump/ relay
About a year ago I replaced the fuel pump on my wife's 03 4.6 EB expedition. I guess it gave out after 120xxx miles. It started up fine right after we installed it. Now, almost a year later, it has died again. We installed a Ford OEM pump, so I have my doubts that it went out for no reason. In addition, in the past couple of years, the car seems to randomly die for no reason. No warning, no signs, just dies. No codes either. Well, after doing some research, I saw a post about how someone else had a similar problem. They discovered the relay in the fuse box melted. I decided to investigate mine. After removing and disassembling the fuse box, I had a circuit board with five relays on it. I'm assuming that one of these is the R303 fuel pump relay. I'm cannot seem to figure out which one it is. There are five in a row and the middle one has what appears to be a burn bubble on the bottom side. Can someone tell me if this is the correct relay? Also, Would this have caused my new pump to short out? Thanks
Thomas
Old 06-09-2012, 11:38 AM
alloro's Avatar
alloro
alloro is offline
Received 4,185 Likes on 2,425 Posts
The fuel pump relay is not in the fuse box.
Old 06-09-2012, 01:16 PM
99f250craig
OK, so tell me where is it? According to the owners manual, it is located in the fuse panel on the passenger-side kick panel. I am not aware of any other power distribution locations on this vehicle. It clearly states that the R303 "fuel pump relay" is located in the passenger-side fuse panel. It is also a non-serviceable relay as it is built in the circuit board.
Old 06-09-2012, 07:19 PM
alloro's Avatar
alloro
alloro is offline
What I meant is that it is not one of the exposed accessible relays that you can change.
Old 06-09-2012, 09:53 PM
99f250craig
I know, I had to take the fuse box apart to see the built in relays on the circuit board. One of them appears to have a hotspot on it. I was asking if the middle relay on that board was for the fuel pump since it was the one that looked damaged. I have already ordered a new fuse panel just to be safe.
How do you test the fuel pump outside of the tank? Can you put 12 volts directly to the pump and make it run?
Old 06-10-2012, 12:01 PM
alloro's Avatar
alloro
alloro is offline
Yes but don't let it run long at all. If it's still good running it dry can ruin it fast.
Old 08-21-2013, 07:55 AM
jc43white's Avatar
jc43white
jc43white is offline
R303
Can you tell me where it is located?
Old 08-21-2013, 03:23 PM
alloro's Avatar
alloro
alloro is offline
Read this: http://www.justanswer.com/ford/2bu7s...7-located.html
DSMTJ
03-24-2023 12:01 PM
javila88
10-08-2018 08:19 AM
rickcaspari
1999 to 2016 Super Duty
27
07-18-2014 09:09 AM
brunomisty
Modular V10 (6.8l)
07-16-2014 09:37 PM
Madmike33
1983 - 2012 Ranger & B-Series
03-29-2007 12:17 PM
Quick Reply: fuel pump/ relay
