fuel pump/ relay - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
fuel pump/ relay
Old 06-08-2012, 08:00 PM
99f250craig 99f250craig is offline
99f250craig is starting off with a positive reputation.
fuel pump/ relay
About a year ago I replaced the fuel pump on my wife's 03 4.6 EB expedition. I guess it gave out after 120xxx miles. It started up fine right after we installed it. Now, almost a year later, it has died again. We installed a Ford OEM pump, so I have my doubts that it went out for no reason. In addition, in the past couple of years, the car seems to randomly die for no reason. No warning, no signs, just dies. No codes either. Well, after doing some research, I saw a post about how someone else had a similar problem. They discovered the relay in the fuse box melted. I decided to investigate mine. After removing and disassembling the fuse box, I had a circuit board with five relays on it. I'm assuming that one of these is the R303 fuel pump relay. I'm cannot seem to figure out which one it is. There are five in a row and the middle one has what appears to be a burn bubble on the bottom side. Can someone tell me if this is the correct relay? Also, Would this have caused my new pump to short out? Thanks
Thomas
Old 06-09-2012, 12:38 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
The fuel pump relay is not in the fuse box.
Old 06-09-2012, 02:16 PM
Quote:
OK, so tell me where is it? According to the owners manual, it is located in the fuse panel on the passenger-side kick panel. I am not aware of any other power distribution locations on this vehicle. It clearly states that the R303 "fuel pump relay" is located in the passenger-side fuse panel. It is also a non-serviceable relay as it is built in the circuit board.
Old 06-09-2012, 08:19 PM
What I meant is that it is not one of the exposed accessible relays that you can change.
Old 06-09-2012, 10:53 PM
I know, I had to take the fuse box apart to see the built in relays on the circuit board. One of them appears to have a hotspot on it. I was asking if the middle relay on that board was for the fuel pump since it was the one that looked damaged. I have already ordered a new fuse panel just to be safe.
How do you test the fuel pump outside of the tank? Can you put 12 volts directly to the pump and make it run?
Old 06-10-2012, 01:01 PM
Quote:
Yes but don't let it run long at all. If it's still good running it dry can ruin it fast.
Old 08-21-2013, 08:55 AM
jc43white jc43white is offline
jc43white is starting off with a positive reputation.
R303
Can you tell me where it is located?
Old 08-21-2013, 04:23 PM
Quote:
Read this: http://www.justanswer.com/ford/2bu7s...7-located.html
Central Junction Box (fuse panel) DSMTJ Excursion - King of SUVs 19 12-20-2016 09:37 PM
No juice to fuel pump crandallf150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 12-10-2016 07:46 AM
Random no fuel pressure at start up. 9rudy9 1999 to 2016 Super Duty 7 02-01-2016 11:46 AM
Engine dies, won't start White Mountain Goat 1987 - 1996 F150 & Larger F-Series Trucks 13 06-11-2014 04:08 PM
Holley pro-jection issue...sorry...long post Fedexbill Aftermarket Products 1 09-02-2011 01:56 PM
Tags
06, 07, 1999, 360, diesel, econoline, expedition, f250, ford, fuel, gas, power, pump, r303, relay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
