Pulled Codes - No Shift into 4th - Any Ideas - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-08-2012, 04:46 PM
dbradicich dbradicich is offline
dbradicich is starting off with a positive reputation.
1FTNX21FX1EA60159
DATE 09/00
I am calling this an '01 F-250 SD 4 x 4 super Cab (door and a half)
No Modifications.. XL with Bench seat,, no fancy stuff.
Pulled Transmission Codes PO728 / PO768
3/4 shift solenoid.
Transmission Fluid fine not burned
Magnetic Chip Detector has some stuff, but no chunks just slime, no disintegration of parts visible.
Changed the Solenoid Pack - Did not fix
Changed speed sensor in Pumpkin (rear axle) - did not Fix
30A Maxi Fuse (#17 was blown) Replaced - did not Fix
Does anyone have the "pin out" procedure to test any other electrical items?
One day the truck would not start when in park, ,had to move to neutral and it started,, the gear lever is all loosey goosey,, but no matter how i wiggle it or where i move it,, still no 4th.
I took column apart to check wire from OD switch - looked fine to me
Basically I just drive around now with the OD Button on - Towing trailers everything, no problem.. just no 4th.
Alternator and one Battery changed recently.. no other crazy stuff done to truck.
IS there ANYTHING ELSE I CAN DO, before I have to take this in and spend thousands on a new transmission?
Old 06-08-2012, 05:06 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
I would take a close look at your "loosey goosey" gear shift linkage.
Old 04-29-2014, 08:04 AM
The answer....
Warped pump. Transmission rebuild.
E4OD to ZF 5S-42 swap break down myakkacracka Clutch, Transmission, Differential, Axle & Transfer Case 13 06-16-2016 12:33 PM
E4OD to ZF 5S-42 swap break down myakkacracka 1987 - 1996 F150 & Larger F-Series Trucks 6 03-17-2014 08:35 AM
2003 6.0 No Start Jnas860 6.0L Power Stroke Diesel 19 07-30-2013 03:54 PM
Input Courtney Williams 6.0L Power Stroke Diesel 32 01-07-2013 10:43 AM
Check Light on, OD light Flashing, trying to stall?? TheInsurancePro Expedition & Navigator 4 08-16-2010 08:37 PM
Tags
2002, 34, 4th, diesel, excursion, f250, ford, gas, shift, shifting, solenoid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
