Misfire but no codes - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 06-08-2012, 01:06 PM
roscozman roscozman is offline
roscozman is starting off with a positive reputation.
2003 Ford Expedition 5.4 ltr Triton is having a misfire but do not get codes mechanic says. He does get a P1780 Transmission Control Switch but does not believe this will cause the misfire. Any help would be greatly appreciated.
Old 06-08-2012, 05:27 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Either ride it hard to force the code to appear or take a drive with a scanner attached that reads live data. With the scanner you will be able to see the misfire in real time.
Old 06-10-2012, 01:04 PM
99Exp 99Exp is offline
99Exp is starting off with a positive reputation.
I had the same thing happen to me and it ended up being a lazy COP. The only way we pinpointed it was to do what Alloro said and drove around with a scanner hooked up.
Old 06-11-2012, 10:24 AM
What is a "lazy COP"?
Thanks.
Old 06-11-2012, 01:02 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
Thanks.
Donuts, coffee, napping in the car...
Seriously, it's COP that is just starting to fail and the rate and incidence of misfires is not severe enough to set a fault code yet.
Plenty of previous threads - SEARCH keywords "+low +grade +misfire" or similar.
Old 06-11-2012, 03:28 PM
Thanks. I did read about the misfire but most people get a code. I believe I have to take my mechanic out for a drive to get a readable code. I now know what a COP is... Coil on Plug.
Old 06-11-2012, 06:21 PM
You don't get a code until the misfire passes a certain threshold.
If you read my posts regarding this from several years ago, you'll know what to tell the mechanic.
Old 06-27-2012, 11:53 AM
Update:
Let me first say... I did a lot of reading and researching. Since advice given here and on many other posts, problem was a COP. Ordered eight new plugs on ebay from global-automotive at a total cost of $65. Had mechanic put in for $60 and everything is running smooth (also bought small tube of dielecrtic grease). Problem fixed. I have put on about 400 miles and still no problems.
Thanks to everyone who gave advice on this post and other posts as well!!
Trouble with misfire OBSGuy45 1987 - 1996 F150 & Larger F-Series Trucks 7 04-05-2016 01:00 AM
Misfire w/Lean daveplot Expedition & Navigator 3 07-09-2011 11:00 AM
Cylinder Misfire fordguy21 3.8 & 4.2L V6 17 01-27-2011 09:11 PM
Engine Misfire kwaskow Explorer, Sport Trac, Mountaineer & Aviator 21 06-22-2010 12:41 PM
04 f150 heritage v6 misfire jsims11 1997 - 2003 F150 2 04-17-2009 10:29 PM
Tags
1780, 2000, 2003, 94, chip, code, codes, edge, expidtion, f150, ford, grade, lincoln, low, misfire, missfire, navigator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
