air conditining re-charge - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-15-2013, 12:14 AM
LongRider LongRider is offline
LongRider is starting off with a positive reputation.
Quote:
Originally Posted by Sw1tchfoot View Post
2. If the oil is added to the system then a vacuum is pulled to get the moisture out, does it pull the oil out that had just been put in the system?
I just had to say that ^^^THIS^^^ is a very good question and your asking saved me from asking.
Many thanks.
Also, many thanks to Archion and others for posting this information.
  #32
Old 06-15-2013, 09:17 AM
bruno2's Avatar
bruno2 bruno2 is offline
bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.
No it will not evacuate the oil.
  #33
Old 06-15-2013, 03:50 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Dropping the pressure in the system to near zero decreases the boiling point of water to so low that the water boils and most of the vapor is removed. But not the oil.
  #34
Old 06-22-2013, 04:08 PM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
Here's my experience with the systems in theses trucks. When I bought my 84 the compressor had no belt on it but was loose. So I pulled a vacuum on it for 45min, I had oil coming out of the evacuator, which told me the system was oil logged. Figured there was alot of oil left in it, so I added none and charged with 134a.
3yrs later headgaskets required the removal of the condensor, so recharge after adding 3oz of ester oil.
3yrs after that (2 weeks ago) compressor failure, got a used compressor, disassembled the old one to find out why it failed. Piston cracked and jammed the metal ball and disk that rides on the swashplate into the next piston and seized the compressor. Left system alone no parts or metal left the compressor. Installed new compressor, evacuated for 90min, charged the next morning. Starting off at 20''hg I added about 38oz, low side was 36psi and high side was around 130. Vent temps hold a steady 33 degrees.
  #35
Old 07-12-2013, 08:12 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is online now
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
Quote:
Originally Posted by Archion
New Orifice tube. - If you have the blue tube factory, go to a red, if you have a red tube factory, go to an orange. If you live in a more extreme climate, I would go with Variable Orifice Valve. There are two by temp range
I am in the process of replacing my entire A/C system. My old orifice tube is blue. What is the purpose of switching to a red orifice tube? And where do I get a red one?
  #36
Old 07-12-2013, 09:58 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The store will have the red ones as well as the blue ones. The orifice tube sets the flow and pressure of the system as it runs. The different gases run more efficiently at different pressures and flow rates. That's about all I know. Yours will run ok with the blue one, it might run even better with the red one. I know the 96 powerstroke system I just worked on had a red valve and it came from the factory with r134a. I believe they also put a larger condensing coil in front of the radiator for the r134a. But these are just tweaks to the system to get it running the best on the different gas.
  #37
Old 07-12-2013, 10:49 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
Dave, FWIW, Ford changed to R134a in 1994. When they did this they changed the condenser to a multipass and the evaporator core was increased in size. The orifice tubes are basically sized originally for the area to be cooled. Archion has the chart somewhere, but I think it was orange, blue, red in order of increasing size. I used a red when I first converted mine. I now have a complete 1996 system installed. Big improvement on it, insulated AC box. Before, if I stopped in hot weather it would take 20 min or more for the air to get cool again, now it's more like 2 min.
One other thing, and I don't know if it was other engines, but the 460 got a smaller compressor pulley (spins faster) starting in 1996.
  #38
Old 07-13-2013, 06:46 AM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
Ford
FOT Color Orifice Size
Blue .067"
Red .062"
Orange .057"
Green .052"
Brown .047"
Or you can go with a variable orifice tube. Others have had good results there as well. They come in two flavors. Standard and extreme climate.
  #39
Old 07-13-2013, 09:21 AM
Thanks Matt, maybe Chris can add this information to the stickies in this forum.
  #40
Old 07-13-2013, 09:39 AM
Gary Lewis's Avatar
Quote:
I was going to suggest the same thing. Good info. I'd rep Matt but can't.
  #41
Old 07-13-2013, 10:07 AM
Same here Gary, I'm still in that adjacent cell. I see they finally got your supporter status restored.
  #42
Old 07-13-2013, 10:34 AM
Gary Lewis's Avatar
Yup, I'm a jock for another year.
A/C Conversion- FINISHED! ng19delta 1987 - 1996 F150 & Larger F-Series Trucks 1 06-19-2016 02:34 PM
Pulling deep vacuum on '92, F-150, Retrofitted to R134A timbersteel Cooling, Heating, Ventilation & A/C 6 06-15-2014 07:50 PM
A/C problem Fixed on 5.4L in 20 Steps. runstang22 2004 - 2008 F150 2 08-08-2013 08:29 AM
Suggestions for A/C Refit? kc5hwb 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-03-2011 02:54 PM
AC Compressor Swap?? jjski78 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-28-2011 12:44 AM
Tags
1982, 1985, 1995, ac, air, charge, charging, conditioner, diesel, f100, f150, f350, guides, orientation, orifice, retrofitting, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
