Hard starting 2001 F350
Went to start my F350 this morning and for the first time was hard to start. The weather here is between 65-110 throughout the day. I have never had any issue except for today and is continuing. I wait for the engine light to go out (Glow plug light) and try to fire the truck up.
It takes several cranks but does fire up. The engine light (glow plug light) comes back on for a cpuple of seconds then goes back out. I run the truck until the temperature is good and hot.
Turn the truck off wait a couple of minutes turn the key to the on position wait for the (glow plug light) to go off then start the truck back up. After the trucks starts up and runs the (glow plug light) comes back on for a couple of seconds then goes out again.
The truck runs good once started but is just hard to start.
my first response and thank you not a lot of bone stock guys
Good point only had this for about a month so the learning curve is steep and at 65 do not need extra wrenching. This is my first vehicle with modules and computers. Will check voltage. Changed oil to Delo which helped war up time Will be using it for road trips when no longer working. Any other seniors out there?
G
G
1985L8000cat3208
09-01-2012 08:15 AM
