P0506 code
Old 06-08-2012, 01:33 AM
Djack04F150XL's Avatar
Djack04F150XL
Djack04F150XL is offline
P0506 code
I recently put on a Volant CAI on my '04 5.4-3v. The engine idles lower than before and I get an occasional P0506 code. I plan on removing and cleaning the T/Body when I have a weekend off. Throttle body has some build up on it. Any other suggestions? Thanks.
Old 06-08-2012, 01:59 AM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,430 Likes on 2,345 Posts
It's a process of elimination to find it. You may need a throttle body or a tune. Look to a good tuner before spending a lot on guess work.
Old 06-08-2012, 11:31 AM
Steve_Uzi's Avatar
Steve_Uzi
Steve_Uzi is offline
I would get a new Throttle body gasket/oring - Most parts stores have to order them... My shop had it the next day.. it only cost $3... Others will say re-use it.. but for $3? Just swap it out for a new one
Old 06-08-2012, 03:46 PM
berry1234's Avatar
berry1234
berry1234 is offline
Pull throttle body, clean only with CRC Throttle body cleaner-others will take off special coating. Take off IAC if your truck has one-if it has a throttle cable it does-if it's drive by wire it won't. Disconnect the battery while doing this. Also you can get a can of CRD MAF sensor cleaner and do that as well. Should take care of it.
Old 06-08-2012, 06:51 PM
Djack04F150XL
Thanks for replies, I was planning on taking off the T/ Body when I get off of 7/12s night shift. Already cleaned the MAS and I'll pick up some CRC T/B cleaner and oring
Old 06-08-2012, 07:21 PM
Ford Agian's Avatar
Ford Agian
Ford Agian is offline
I would look deeper. Do a few searches around here it's my belief that the '04's don't have the flexability in the computer to adjust for all the extra air and I believe the only fix is custome tunes to bump up the fuel...
John
Old 06-18-2012, 10:18 AM
Djack04F150XL
Finally got time to R+R throttle body this past Saturday. Lot of build up in and below it. Cleaned and replaced it. Runs great now. Thanks again for input.
Old 06-29-2012, 09:08 PM
lakeforkfisherman's Avatar
lakeforkfisherman
lakeforkfisherman is offline
Lucky you. I had the same code and the throttle body had to be replaced. $700 at the mechanics.
mayerst
01-09-2022 07:10 PM
Qwazert
6.2L V8
07-01-2019 07:59 PM
makuloco2000
Transit Connect
01-20-2014 10:46 PM
SCEPTRE2000
01-29-2011 03:10 PM
SJHanlo
16
02-20-2005 08:57 PM
Quick Reply: P0506 code
