Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-08-2012, 12:44 AM
fishbone1 fishbone1 is offline
Garage is empty, add now
fishbone1 is starting off with a positive reputation.
2007 f150 has coolant in oil
Here is a little background. 2007 f150 4.2 2wd auto 119,000 miles. I purchased the truck with 111800. At approximately 117500 the truck overheated. It was over 1 gallon low on coolant. I topped off the coolant and checked for leaks. I could not find any leaks. At 119000 miles I noticed my coolant reservoir was almost empty again. I topped off and thoroughly looked for external leaks. I could not find any. I changed the oil. I didn't see any water but oil did have some bubbles on top. I pulled all the spark plugs. They looked good. Yesterday morning I added a bottle of UV dye to the coolant reservoir. I drove the truck to work tonight. My motor oil has a faint glow from the ultra violet dye now . The underside of the oil fill cap really glows. So, the coolant is definitely making it into the oil. How do I diagnose this further? I thought the gasket problems were corrected on the newer 4.2 engines. I was just getting ready to sell the truck. I don't want to sell until I fix this problem.
__________________
[b]1981 F100 300cid 3 speed manual
  #2 (permalink)
Old 06-08-2012, 11:27 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Being over-heated caused your gasket problem.
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 06-09-2012, 08:37 AM
What is your guess? Intake gasket, head gasket, or cracked head? Should I just start pulling the top end apart and looking for a bad gasket?
__________________
  #4 (permalink)
Old 08-02-2012, 11:17 PM
It was a bad lower intake gasket. No more coolant loss.
__________________
Tags
2005, 42, 50, coolant, ford, oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
