Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-07-2012, 09:08 PM
sawz5 sawz5 is offline
Garage is empty, add now
sawz5 is starting off with a positive reputation.
99 2.5 problems
i bought this 99 ranger supposedly in good running condition, BUT you all know what's coming right. i had my nieghbor put his scanner on and he says it may have a broken or weak valve spring on no.2 cyl. now since he is remodeling his son's house he don't have time. so i need help from some of you guys. i need step by step how to change a valve spring in an overhead cam engine. thanks, rick
  #2 (permalink)
Old 06-07-2012, 10:32 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
How did the "scanner" tell you that it's a valve spring problem.
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 06-09-2012, 06:04 AM
i guess i should have said his scanner showed a misfire on no.2 cyl. then he said it might be a weak or broken spring.
  #4 (permalink)
Old 06-09-2012, 01:07 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to all
A misfire can be caused by many things, such as a bad plug/plug wire, coil problem, or fuel injector issue. Even a small vacuum leak can cause a single cyl to have a misfire.
Yes, a weak or broken valve spring can cause this, but check the external stuff first. Especially if the misfire is intermittent.
__________________
1980 F-150 300 I6, C6 & 9" rearend. The workhorse. 300K+
1974 F100 Ranger XLT 390, C6 3.25 axle. Dad bought it new, drove it over 500K. Now that he can no longer drive it came to me. Value: Priceless.
1983 Mazda RX7 1.1L Rotary. The show/autocross/toy. 231K
1995 Mazda B2300 (undercover Ford)
  #5 (permalink)
Old 07-03-2012, 10:01 PM
thanks Mr. Rogue, apperantly a broken or weak valve spring can be fixed by changing to
a lighter weight oil. i put 10w40 in when i changed the oil my mech. found a thech paper from ford saying use 5w20 because heavier oil stayed in the lifters causing them to hold th valve open. i changed to 5w20 and so far the engine is running ok, so i guess i'll wait to see the outcome.
Tags
25, 54, 99, ford, ranger, recalls, spring, tap, valve, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
