93 F350 4x4 gas front leaf spring code
Old 06-07-2012, 08:43 PM
BearFootCustom's Avatar
BearFootCustom
BearFootCustom is offline
Almost ready to do my dana 60 swap, just need new leaf springs. Anyone know what code they are? Thanks
Old 06-11-2012, 12:48 PM
BearFootCustom
Anyone????????
Old 06-11-2012, 06:10 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
Check these codes by your Vehicle Certification Label.
Old 06-11-2012, 08:30 PM
BearFootCustom
Thanks but I have a f250 that i wana put f350 front leaf srings in
Old 06-11-2012, 08:41 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
There are at least 3 different spring codes
small block
big block/diesel
cab-n-chassis
Old 06-12-2012, 04:42 PM
BearFootCustom
Then I need small block ones
Old 06-12-2012, 05:56 PM
joshh's Avatar
joshh
joshh is offline
are your springs shot my 250 seems to have the same springs as my buddies 350 ( both crewcab diesel)
Old 06-12-2012, 06:26 PM
Diesel_Brad
F250 and F350 springs are NOT the same
Old 06-12-2012, 07:02 PM
joshh's Avatar
joshh
joshh is offline
ok not saying ur wrong but what is the differnce? im curious now
Old 06-12-2012, 07:29 PM
Diesel_Brad
F250 springs are arced downward and have a HIGHER spring rate than the F350 by around 1200lbs
YES the F250 has a HIGHER rate spring. It is due to the PIS POOR Design flaw of the TTB and how it makes the leaf spring flex in ways they were never designed to
Old 06-12-2012, 07:31 PM
joshh's Avatar
joshh
joshh is offline
intersting guess mine are just sagging then look to have same arch as his
also on that note wouldnt the op be better off keeping his stock springs for the swap
Old 06-12-2012, 07:59 PM
Diesel_Brad
No, the rearched F250 spring have such a High rate they will give a kidney jarring ride and will sit Lower than A F350
Old 06-13-2012, 03:01 PM
joshh's Avatar
joshh
joshh is offline
nevermind my dumb comment i read ur post backwards thinking u were saying the 250 had more arch making it sit higher
was long day guess i should of went to bed instead of posting last night
Old 06-13-2012, 03:49 PM
firewood truck's Avatar
firewood truck
firewood truck is offline
When I converted my F250 to the Dana 60 front end, I went to a local leaf spring shop in Baltimore called Middleton and Mead, they showed me the catalog that had the different available springs, there was no distinction between small block, big block/diesel or cab and chassis. The aftermarket springs were divided up between F250 and F350 with each category having 4 different springs available, all depending on the spring rate that you needed. The different springs had a different number of leaves in the pack.
I ended using a 2 ply F350 spring then having them de-arched about 1.5" so that the truck wouldn't be jacked up in the sky, they matched very well to the new rear springs I installed a year earlier.
Do yourself a favor and call a reputable spring shop and talk with someone who knows what they are doing instead of being mis-led by the interweb know-it-alls that seem to lurk on this site.
here's a link that has some decent listings for front leaf springs.
www.sdtrucksprings.com
Old 06-13-2012, 08:03 PM
Diesel_Brad
Leaf Springs, Helper Springs and Suspension Parts | SD Truck Springs
Unfortunatly the aftermarket doesnt match springs like the OEM does. There is INDEAD a difference between the small block, big block/diesel and cab-n-chassis springs. You do realize the small block weighs about 500 and the big block about 750 and the diesel is 925
Ford didnt just put a different spring code on the door jam sticker for the hell of it. They all have different weight ratings. As for the 2 or 3 leaf deal. EVERY f250 and F350 left the factory with only 2 leafs. The aftermarket came up with the 3 leaf deal for the extra weigh of plows and winch bumpers.
I have been working on these trucks for over 20 years, I am NOT an internet know it all. The level of my craftsmanship and the NUMEROUS truck I have built should more than attest to that
Quick Reply: 93 F350 4x4 gas front leaf spring code
