7.3 IDI Turbo question
Hi Guys
I've got a pretty basic question regarding the turbo on a '93 IDI 7.3. I am fairly convinced that it is not putting out proper boost but I have no diagnostic equipment, it has no sound to it as it had when I first bought the truck 3 years back and the power is really lacking. My inquiry is, if the truck has been warmed up at idle for a few minutes, should the turbo housing be fairly warm? This one is cold to touch, the rear section (the part that is wrapped with heat shielding) is fairly warm, but not as warm as I would expect.
Any ideas much appreciated.
here is the boost gauge i started with. you can run either boost or vac.
Buy Sunpro Style Line Mechanical Vacuum/Boost Gauge - Black Dial CP8213 at Advance Auto Parts
