DiMora's 400 build - part deux - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-22-2012, 06:34 PM
danlee's Avatar
danlee danlee is offline
danlee has a good reputation on FTE.danlee has a good reputation on FTE.danlee has a good reputation on FTE.
I have one in the 302 motor in my '83 F100. I'll have to take a look at that, and also look at the manual that came with it.
Did you get an Instruction Manual and pigtail connector from Summit?
The 3 wires in the Ford harness are +12V, Ground, and the Tach/Trigger Signal. The Tach/Trigger Signal goes to the Ignition Module, and fires the coil.
With the HEI setup, you no longer need the Ignition Module. The 2 wires are +12 V Power and the Tach signal. The +12 Volt should be Switched Power. It is live when the Keyswitch is in Start or Run position.
  #32
Old 08-04-2012, 10:31 PM
dimora's Avatar
dimora dimora is offline
dimora is starting off with a positive reputation.
The build is coming along.
I got my block back (with cam bearings and freeze plugs installed by my machinist) and I painted it Ford blue, along with the oil pan.
I also mocked up my intake manifold along with carb and a new HEI distributor (Summit Racing branded Proform-built unit) to make sure my air cleaner was going to clear the giant HEI coil.
My crank is back (Ground .010/.010) and polished. I am waiting on a new damper (mine is old, brittle, and the rubber is cracked) and then I can get my rotating assembly balanced.
I rebuilt my carburetor today...it was nasty. It was manufactured in 1998 and I have never rebuilt it, so it needed it badly.
I'm also cleaning up and painting the engine bay while the engine is out.
Pics from today:
Edelbrock 1405 600 CFM manual choke all torn down...
Block and oil pan painted:
Mocked up without heads to check distributor / air cleaner clearance along with freshly cleaned carb. It just barely fits!:
  #33
Old 08-05-2012, 05:08 AM
danlee's Avatar
Looks good, keep us up to date.
  #34
Old 08-06-2012, 11:57 AM
dimora's Avatar
Engine bay clean-up underway...
Degreased, pressure washed, and the black part of the bay has been painted; edges and base of windshield to firewall to follow. I'll post better pictures with my Canon later on when I get it all done:
  #35
Old 08-08-2012, 11:06 PM
dimora's Avatar
Taped...
...and painted:
A little wire management, some wiper painting, and she'll be ready for her new heart!
  #36
Old 09-09-2012, 07:59 PM
dimora's Avatar
I got my short-block built: Crank installed, Cam installed, and all 8 pistons installed. I balanced it (got to do it myself with my buddies help) on a CWT Multi-Bal 5500 balandcing machine, and I had my rods re-conditioned at my local machine shop (Goza Machine, Acworth, GA).
I am using all ARP fasteners on this build...so I now have ARP connecting rod bolts and ARP main cap bolts.
Hastings rings were used on Tim Meyer's KB2344 pistons for Aussie heads.
I'll post up pics tomorrow if I have time.
Question for you experts: Is there an "oil slinger ring" on a 400? My Tom Monroe book mentions to install an oil slinger ring on the crankshaft (after installing the crank timing gear), but I do not recall seeing one...I am thinking it only pertains to 460's, as the book covers all builds, but if anyone knows for sure now is the time for me to find out before I put on the front cover and damper.
  #37
Old 09-09-2012, 08:10 PM
danlee's Avatar
I believe that there is a ring on the crank to deflect the oil away from the front seal, but my memory foggy.
  #38
Old 09-10-2012, 05:45 PM
crsmiffy crsmiffy is offline
crsmiffy is gaining momentum as a positive member of FTE.
x2 on the ring-it is there
  #39
Old 09-15-2012, 07:05 AM
dimora's Avatar
Quote:
Quote:
Interesting...alright, the Ford factory service manual does not show it for a 400, only a 460, but both of you recall it, and I e-mail Tim Meyer and he stated that they used to have them and use them, but they are no longer necessary and he hasn't used one in years.
So...I'll go without.
  #40
Old 09-15-2012, 04:34 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
i run this!
i like this on my 4wds that run at extreme angles. helps out a little i guess. i can't prove this but it can't hurt just by design it looks like its good.
  #41
Old 09-15-2012, 04:37 PM
dimora's Avatar
Quote:
Run what? A slinger? Do you have a picture?
  #42
Old 09-22-2012, 07:31 PM
ALL AMERICAN BOY's Avatar
ALL AMERICAN BOY ALL AMERICAN BOY is offline
ALL AMERICAN BOY is starting off with a positive reputation.
dimora
still building your 400?
have a nice day!
  #43
Old 09-22-2012, 08:39 PM
TMI's Avatar
TMI TMI is offline
TMI is starting off with a positive reputation.
He's probably waiting for some pokey machine shop to finish his heads!!
Heads should be out the door very soon for you Shane!!
  #44
Old 09-23-2012, 07:17 AM
dimora's Avatar
Quote:
Originally Posted by ALL AMERICAN BOY View Post
dimora
have a nice day!
I'm waiting on my oil pump to button-up the bottom end, Lunati hydraulic roller lifters, pushrods, and my heads - all coming from Tim Meyer Inc.
They (heads) are being built right now by Cory at TMI...with bronze valve guides and stainless steel valves, and the following supporting parts:
Comp springs (924-16)
Comp Retainers (741-16)
Comp Valve locks (611-16)
Comp Teflon valve seals (503-16)
Once Tim gets the above to me (minus push-rods), I'll clay the piston to valve clearance, determine push-rod length, and order the push-rods from Tim and get it buttoned-up and installed.
Thanks Tim!
  #45
Old 09-23-2012, 06:40 PM
dimora
sounds really cool.
later.
Cam questions JRS2 1987 - 1996 F150 & Larger F-Series Trucks 28 06-25-2016 07:02 AM
Can someone run some desktop dynos for me? NIdude Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 04-14-2015 10:25 PM
To Hyd. roller cam or NOT to Hyd. roller cam LindenBruce FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 03-10-2010 08:57 AM
How much HP and torque DarkWolf40 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 11-27-2004 02:14 PM
does anyone have a desk-top dyno? moore89 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 13 03-24-2004 12:55 PM
Tags
1978, 29, 400, bent, boring, ford, overheated, overheating, pump, pushrods, starvation, std, tappets, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
