Need Help Decoding Vin # For 1964 Econoline Truck
Old 06-07-2012, 01:27 PM
HermansE100's Avatar
HermansE100
HermansE100 is offline
Hello ! I'm new to this site as well as the new owner of a 1964, Ford Econoline Truck. I need help decoding the vin #. The door vin # matches the rear bracket below the tail light. Just curious to see if it matches what the seller indicated was the actual year on the truck.
Old 06-15-2012, 06:22 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by HermansE100
Hello ! I'm new to this site as well as the new owner of a 1964 Ford Econoline Truck. I need help decoding the vin # as well as the other info located on the door panel plate.
The door vin # matches the rear bracket below the tail light. Just curious to see if it matches what the seller indicated was the actual year on the truck, so here goes:
Vin # E10AH803930
Welcome to FTE
E10 = E100 Pickup.
A = 240 1V I-6
H = Lorain OH Assembly Plant.
803930 = 1966 .. assembled January 1966.
Old 06-15-2012, 10:52 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Old 06-15-2012, 03:44 PM
HermansE100
66 Econoline
Hi and thanks for the info, truly appreciated. I suspected it was at least a 1965, but wasn't sure. Either way its a great truck, glad to have it.
Old 06-16-2012, 07:03 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
Post the rest of the data on the door plate, and we can decipher that as well.
Welcome to the Econoline Club!
Old 06-19-2012, 10:30 AM
HermansE100
Thanks, have picked up several manuals that have helped me with the rest.
Old 09-23-2015, 08:23 AM
gd2go11's Avatar
gd2go11
gd2go11 is offline
Need help decoding vin # for 1964 econoline truck
I don't understand the mechanics of figuring out the year. Can you explain?
Old 09-30-2015, 05:41 PM
NumberDummy
The serial number (last 6 digits of the VIN) decode to the month/year of assembly.
1961/63 examples:
Old 10-01-2015, 04:48 PM
gd2go11's Avatar
gd2go11
gd2go11 is offline
Thank you for your time. Can you post the numbers for 64-65. I may be taking it to the DMV. Again thank you.
Old 10-03-2015, 12:42 PM
EmilBarnabas
Go here to see all the dates for the 1961-1967 Econolines.
Econoline Assembly Dates
Post your door tag data here for a complete report
Econoline ID
CharityTruck
02-04-2014 03:00 PM
hanksy
08-17-2013 08:07 PM
PRY046
25
07-21-2013 11:27 PM
ShadowSnowLeopard
21
01-28-2013 07:47 AM
ryan.mcelroy.87
1947 and Older Ford Trucks
08-13-2012 09:18 PM
Quick Reply: Need Help Decoding Vin # For 1964 Econoline Truck
