scraping sound on hard left turn - Ford Truck Enthusiasts Forums
Old 06-07-2012, 02:13 PM
v10kenj v10kenj is offline
v10kenj is starting off with a positive reputation.
I'm getting a scraping sound on hard left turns. I've only noticed it on a steep hill where I work going under five mph and making a sharp left turn. I got out today and it doesn't look like the tire is hitting anything. The shield in front of the tire is slightly looser than the right side, but can't see it making the noise unless something is hitting it. I've read some previous posts that indicated traction control possibly coming on. Has anyone experienced similar? I have about 4,000 miles, 20 inch tires, and everything stock.
Thanks
Old 06-07-2012, 03:46 PM
BigDfromTN's Avatar
BigDfromTN BigDfromTN is offline
BigDfromTN is gaining momentum as a positive member of FTE.BigDfromTN is gaining momentum as a positive member of FTE.
Had a similar thing happen when pulling into my drive. Hard left turn etc. Same tires and stock.
I have not investigated as only happened once. Sounded like a tire rubbed to me...
Old 06-07-2012, 05:03 PM
awq134's Avatar
awq134 awq134 is offline
awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.
I'm betting it's your traction control applying the brake to that wheel. mine does the same thing when i make a sharp on uneven ground.
Old 06-07-2012, 06:45 PM
Quote:
I was hoping you were right, but just tried it out with traction control off and it's doing the same thing. Talked to the dealer and their saying " if it doesn't do it on flat ground, which it doesn't it's going to be hard to duplicate and diagnose"
Old 06-07-2012, 07:13 PM
awq134's Avatar
Quote:
about the only other thing i could think of is your CV joint may be binding if it's a 4x4, but i'm guessing it's a 4x2 since you have the 20" wheels
Old 06-07-2012, 10:10 PM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
I have a similar issue on mine, turn a sharp corner and hit a bump (small or large). It sounds like the ABS kicking in even if I'm not on the brakes. I'm suspect of the traction control.
Old 06-08-2012, 09:01 AM
It is a 4X4. The dealer had swapped the rims out before I bought it with someone who wanted the 18's. If I had know better at the time, I would have insisted that they put a set of 18's back on. That said, I believe that all new lariat, platinum, and king ranch 4X4 trucks come stock with 20in wheels.
Old 06-08-2012, 09:03 AM
BigDfromTN's Avatar
My 4x4 has the 20" wheels. Many of them do.
Old 06-08-2012, 11:29 AM
I did notice that on top of the ball joint bracket on each side there is a circular piece of steel that sticks out a bit and has a small amount of what looks like black tire marks. The right side looks like its marked a little more. I think this is probably a tire stop, but I don't think it would make the scraping noise I'm hearing.
Old 06-08-2012, 11:33 AM
black_dog black_dog is offline
black_dog is starting off with a positive reputation.
...That said, I believe that all new lariat, platinum, and king ranch 4X4 trucks come stock with 20in wheels.
I have a 2011 Lariat 4x4 that came stock with 18" wheels. Maybe your dealer would trade you if you'd prefer the 18".
Old 06-08-2012, 12:13 PM
Quote:
The owner has two Ford dealerships within about 20 miles. I asked both if they would swap my 20's for 18's and they didn't want to. I had about 2,500 miles at the time and maybe they didn't want to put my 20's back on a new truck.
Old 06-08-2012, 12:42 PM
BigDfromTN's Avatar
I have asked dealers about that in the past and they were not willing to due to the wheel size is listed on the window sticker. Some times they trade trucks with other dealers and if they change the wheels... They cant trade it any longer.
Old 06-13-2012, 08:52 PM
nmfiredawg nmfiredawg is offline
nmfiredawg is starting off with a positive reputation.
IS this on the front right? My 2011 F150 does it when turning left on uneven terrain. I thought there was a TSB out on the steering rack for this, since there has been numerous people complaining on it.
Old 06-14-2012, 12:00 AM
SurgIcaltactic SurgIcaltactic is offline
SurgIcaltactic is starting off with a positive reputation.
Lightbulb
Check your shock for scrape marks. When I added the 1 1/2 inch spacer the left shock had scrape marks, seems to be from the coil. Turning right on mine, hit any bump and you hear the noise.
Old 06-17-2012, 06:43 AM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
How long did you depress the TC button? You need to hold it for ~ 6 seconds or so until it starts blinking on the dash. At least thats how mine is, I have the same issue- if I don't disable it sounding like the tire is scraping.
Pickup torque convertor problem/diagnosis? guessrow Clutch, Transmission, Differential, Axle & Transfer Case 0 10-27-2013 09:47 PM
noise when in a hard left turn fordf150guy 1999 to 2016 Super Duty 3 03-25-2012 03:50 PM
grinding or scraping noise when i hit a bump snoopt1 1997-2006 Expedition & Navigator 2 07-02-2011 02:50 AM
04' Mariner - rear end roar? Silverdawg Escape & Escape Hybrid 3 06-14-2009 09:02 AM
2000 f250 4x4 hub noise Pearlwhite94 1999 - 2003 7.3L Power Stroke Diesel 14 07-26-2008 04:16 PM
Tags
2010, f150, hard, left, making, rear, rubbing, scrap, scraping, sound, stock, tire, turn, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
