scraping sound on hard left turn
I'm getting a scraping sound on hard left turns. I've only noticed it on a steep hill where I work going under five mph and making a sharp left turn. I got out today and it doesn't look like the tire is hitting anything. The shield in front of the tire is slightly looser than the right side, but can't see it making the noise unless something is hitting it. I've read some previous posts that indicated traction control possibly coming on. Has anyone experienced similar? I have about 4,000 miles, 20 inch tires, and everything stock.
Thanks
Thanks
I was hoping you were right, but just tried it out with traction control off and it's doing the same thing. Talked to the dealer and their saying " if it doesn't do it on flat ground, which it doesn't it's going to be hard to duplicate and diagnose"
about the only other thing i could think of is your CV joint may be binding if it's a 4x4, but i'm guessing it's a 4x2 since you have the 20" wheels
It is a 4X4. The dealer had swapped the rims out before I bought it with someone who wanted the 18's. If I had know better at the time, I would have insisted that they put a set of 18's back on. That said, I believe that all new lariat, platinum, and king ranch 4X4 trucks come stock with 20in wheels.
I did notice that on top of the ball joint bracket on each side there is a circular piece of steel that sticks out a bit and has a small amount of what looks like black tire marks. The right side looks like its marked a little more. I think this is probably a tire stop, but I don't think it would make the scraping noise I'm hearing.
The owner has two Ford dealerships within about 20 miles. I asked both if they would swap my 20's for 18's and they didn't want to. I had about 2,500 miles at the time and maybe they didn't want to put my 20's back on a new truck.
I have asked dealers about that in the past and they were not willing to due to the wheel size is listed on the window sticker. Some times they trade trucks with other dealers and if they change the wheels... They cant trade it any longer.
How long did you depress the TC button? You need to hold it for ~ 6 seconds or so until it starts blinking on the dash. At least thats how mine is, I have the same issue- if I don't disable it sounding like the tire is scraping.
