2010 Lariat-Blowing cold air on driver's side
Old 02-02-2011, 05:53 PM
doocrue's Avatar
doocrue
doocrue is offline
Hi guys, I have a problem with my Lariat blowing cold air on the driver's side. It happened last weekend when it was snowing hard and drove around town for a couple hours with defrost on. After I got out on the interstate the cold air was blowing in through the vent on the driver's door and down by my feet. It was -4 driving home. I though that some ice may have gotten in and jammed a damper open allowing cold air in. I took the truck in and thawed it out and the same thing happens. Cold air out of drivers side and hot air out of the passengers side. The truck has the dual heat/cool setup and it seems as if the driver's side is stuck on cold but I have it set on just driver. Has anyone experienced this since the heat comes in handy. It was only -25 this morning. Thanks
Old 02-02-2011, 06:25 PM
F-series Fan's Avatar
F-series Fan
F-series Fan is offline
2010 should be under warranty yet, I'd take it to the dealer to avoid any chance of warranty voiding. But I feel your pain I used to live in Minnesota and lost a heater core, got fumigated and instant fog at -30, That was fun trying to see on the freeway. It probably looked like something from a Cheech and Chong movie to the passers by.
Old 02-02-2011, 07:20 PM
Wilber15's Avatar
Wilber15
Wilber15 is offline
Needs a temp blend door motor. It is mounted to the bottom of the hvac case, and to get to it you need to remove both the dash and the heater housing. It's a fun job(I've done some). Good luck! Take it to the dealer.
Old 02-02-2011, 08:50 PM
doocrue's Avatar
doocrue
doocrue is offline
OMG, are you serious. What would cause this? The truck has 5500 miles on it. I want my truck by the weekend cause I want to go ice fishing. How long you think it would take to fix?
Old 02-07-2011, 05:02 PM
polarisnchevy's Avatar
polarisnchevy
polarisnchevy is offline
I am bringing my 2010 with 5600 miles in for the exact same problem. Drove it in the midwest blizzard last week.
Old 04-22-2012, 08:05 AM
johnholl's Avatar
johnholl
johnholl is offline
This is a 2009. How much would this job cost? I'm assuming it's not covered under war.
Old 04-22-2012, 10:15 AM
doocrue's Avatar
doocrue
doocrue is offline
Wow, I see this post resurfaced again. I was the OP on this thread over a year ago. It was strange but the problem corrected itself. I didn't have any issues with it this winter but we really didn't have much snow either. If your truck is an '09 it would depend on when you bought it since it should be the 3yr/36,000 warranty. Good luck
Old 04-22-2012, 11:31 AM
johnholl's Avatar
johnholl
johnholl is offline
thanks, I'll go and see exactly when my father purchased the F150, I know it's a 2009. I'll first check to see if the coolent is flowing thru the core.
I do not trust his Ford dealer. That's my main problem. They've got the New Car market all to themselves, and they know it [when it comes to service] I'm pretty shrewd when it comes to this dealer.
And if it's covered...I'll make sure it's covered.
Thanks!
jh
Old 04-22-2012, 01:59 PM
johnholl's Avatar
johnholl
johnholl is offline
Thanks!
jh
Truck was purchased in August 2009, only 30k miles. so it should be covered as a warranty repair, correct?
Old 06-02-2012, 02:25 PM
reighnman's Avatar
reighnman
reighnman is offline
delete delete delete
Old 09-23-2012, 07:23 PM
mldmkr1960's Avatar
mldmkr1960
mldmkr1960 is offline
I have this problem with my 2010
Mine blows cold on the passenger side and my 2010 has 75,000 any ideas what this will cost?
ghunt
07-14-2020 09:07 PM
GARY GAHAGAN
2009 - 2014 F150
02-03-2017 05:54 PM
boatnfish
2009 - 2014 F150
18
02-22-2016 07:58 PM
Suicidal
1999 to 2016 Super Duty
12-08-2015 01:39 PM
polaris192
04-03-2011 02:39 PM
Quick Reply: 2010 Lariat-Blowing cold air on driver's side
