Supercab headliner....cheap - Ford Truck Enthusiasts Forums
Old 06-07-2012, 12:47 PM
84espy 84espy is offline
84espy has a good reputation on FTE.84espy has a good reputation on FTE.
I've been reading about headliners done for single cabs (great job) and decided I had to do something about my 75 SC. First here are the pics, then I'll give the details.
I pulled a headliner from a mid 80s SC that I figured was in good shape. Of course, there are the differences, like the visor mount and the dome light. Since I was only interested in getting a headliner in, I left the visor mount holes, but grabbed a dome light and installed it as non-functioning. Maybe later, I'll make it functional.
If you want to install this as a one piece item, it MUST be a two man job! I was by myself, so I opted to cut the headliner in two to make the install work. I also made a cover strip to take up the gap. This works for me.
When measuring for your SC, the most important item is to mark your trim, remove it and re-assemble it to make the correct pattern on the headliner. You will have approximately 4 inches front to back and a 1/2 inch on each side that will need to be trimmed. I used a sheetrock knife for the initial scoring and then scissors to finish the job. You don't need to have the material overlap, as it will tuck inside the trim.
This job took about 2.5 hours total to install. The biggest hassle was make sure it came out of the donor unscathed and then transport it home. Note: Save yourself some time and DO NOT try to slip this into your SC for an initial fit!
Like I said, this job worked for my beater and I can live with all the flaws that you see in the pics. Most will opt for the one piece install, and it should look great. Good luck with your attempt.
Made changing a flat faster! 84espy General Automotive Discussion 3 01-16-2017 05:01 PM
Eureka! Headliner Gold!!! 84espy 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-31-2015 04:58 PM
My new mod 84espy 1973 - 1979 F-100 & Larger F-Series Trucks 12 12-02-2013 07:29 PM
My shoulder harnesss mount mod 84espy 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-12-2013 01:10 AM
Wiper Mod with pics (Long) 84espy 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-04-2013 06:33 AM
Tags
1997, cheap, f150, ford, headliner, inexpensive, northern, replace, truck, va
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
