Ultra Motorsports Goliath 20x9
Can't imagine going from my stockers (which I believe are 20x8) to these 20x9 would require anything else, especially if I plan on just using my stock tires (Michelin's site says they are good to 9.5" rims). Plan to go bigger (315s) whenever I get around to a lift kit/shock/strut upgrade.
I just think they are bad **** and, aside from buying and powdercoating on your own, you can't get these from Tuscany or from Ultra (custom finish just for Tuscany).
on
Looks like your offset will change. Stock are +40mm. Those look like at least 0 or even - a bit. That will push the wheels out a bit. Should be OK with stock tires. If you go with bigger tires on the stock suspension you may have a problem. I tried -10mm offset with 325/60R20 and it hit hard front and back of the wheel well, could only drive straight, no turnin'.
They look pretty sweet BTW!
So I did jump in and get these. Too good a deal to pass up ($600 for all 4). By my measurements, they are a 0 offset (9" wheel, 5" backspacing).
So thinking with the stock 275/65/20's, I can get away with using these rims with the stock tires until I get around to doing lift/level/etc down the road (I want to go with mudders eventually, but likely next spring when funds will allow). Any wheel/tire gurus here that can confirm that I should be able to run the 0 offset without any issues?
Now, waiting on my friend to check out a BakFlip G2 down in Houston for me. :grin:
Tricon
2017+ Super Duty
18
04-15-2017 01:55 AM
