1978 F-150 Bed Replacement
Old 06-07-2012, 08:19 AM
bigred513's Avatar
bigred513
bigred513 is offline
1978 F-150 SWB 117" 4 wheel drive. The bed is in rough shape and I am looking to replace it. Would a 73-79 f100 bed fit? What year and models would work?
Old 06-07-2012, 08:42 AM
jmm's Avatar
jmm
jmm is offline
all models from 73-79 work.
Old 06-07-2012, 09:21 AM
Ford F350 Supercab's Avatar
Ford F350 Supercab
Ford F350 Supercab is offline
Except some from F350's where the frame is a bit narrower.
Old 06-07-2012, 09:41 AM
Blackfoot Big Block's Avatar
Blackfoot Big Block
Blackfoot Big Block is offline
I don't think any F-250 or F-350 beds would work.
IIRC All F-250's had a 133" wheelbase (long bed) and all F-350's were all long bed with either a 133" or 140" wheelbase.
The OP has a 117" wheelbase which is a short wheelbase truck.
Old 06-07-2012, 10:32 AM
bigred513's Avatar
bigred513
Thanks that is what I was needing to know. I have found and F100 that has a good donor bed, just wanted to make sure the F100 and F150 would swap they do have the same WB of 117 for a short bed. This is my first ground up rebuild of a F-150.
The f-250 and F-350 has a 133 WB and would not work unless fabbed the bed.
Old 06-07-2012, 01:26 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
A short bed is a short bed. No difference.
Old 06-07-2012, 01:38 PM
79CAMOFORD's Avatar
79CAMOFORD
79CAMOFORD is offline
Agreed with Jon
Old 06-07-2012, 04:31 PM
bigred513's Avatar
bigred513
True about a short bed is a short bed didn't look at it that way till now.
Old 06-10-2012, 11:16 PM
98SVTCobra's Avatar
98SVTCobra
98SVTCobra is offline
Bigred, if you need any parts I'm parting out 78 f150 4wd swb. Pm me what you need and ill see if I got it. I'm about 1hr south of you in Hayden, AL.
Old 06-10-2012, 11:29 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
What's the wheelbase of Regular Cab 1973/79 F100's, 1975/79 F150's w/8' beds? 133"
Short Styleside beds will also be found on F100/350 Super Cabs & F250/350 Crew Cabs.
Left quarter panel (bedside): 1973/76 Stylesides have exposed fuel cap(s), while 1977/79 Stylesides have the fuel cap(s) behind doors.
Old 06-13-2012, 04:05 PM
bigred513's Avatar
bigred513
The regular cabs with an 8 ft bed do have a WB of 133". Mine has the short bed with a wheel base 117"
I have noticed the the open fuel caps vs the ones that are closed. Thanks for the info.
Old 02-21-2014, 10:19 AM
Custom73's Avatar
Custom73
Custom73 is offline
Hi instead of starting a new thread i just figured i would ask my question here sense it is similar. I have a 1973 F-100 long bed Custom single gas tank will a 1978 f-150 with dual tanks Fit my Truck?
Old 02-21-2014, 10:47 AM
paredneck33's Avatar
paredneck33
paredneck33 is offline
Yes but you will need to get the correct fuel filler neck for the truck bed. Since Number Dummy already posted the differences in the bed side from 73-76 compared to the 77-79 beds. The filler necks were also changed to match the differences in the bedsides. But yes they will bolt right on. As the mounting points are the same.
Old 02-21-2014, 11:11 AM
Custom73's Avatar
Custom73
Custom73 is offline
Thanks! Much appreciated.
Old 03-23-2015, 11:10 PM
hoss73ford's Avatar
hoss73ford
hoss73ford is offline
Any 1973-79 F100/F150 bed will work but there are a couple of differences. In 1977, the gas fillers had doors put onto them instead of the external screw on caps. Bed will still work but you'll also need the gas filler pipes to match. Secondly, many of the 1978-79s and some '77s had a difference in exterior trim compared to the 1973-76s. New exterior trim to match is expensive.
Quick Reply: 1978 F-150 Bed Replacement
