Need New Fuel Tank. Vendor/Brand? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 06-07-2012, 05:55 AM
gravityfiend gravityfiend is offline
gravityfiend is starting off with a positive reputation.
My 2002 7.3 E-350 original tank began to self destruct in 2010. It completely fouled the fuel system with grunge. I replaced it with a used unit that looked good on the inside... but now this one too has flaked out on me too. It also killed another fuel pump in the process.
New tanks from Ford are $750 bucks. I found one for $224 shipped. Its brand name is "Action Crash" and it claims to be a "NEW" unit even though the name implys otherwise.
"Part" of the vendors name is "Geek" and no one there answers the phone or email. A search of the forum has born no fruit.
Anyone know anything about this tank, vendor or have another recommendation?
Old 06-07-2012, 06:09 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Action Crash is allied with Keystone Corp, both widely known in the collision repair business as huge suppliers of imported aftermarket parts. Also part of their network seems to be an outfit known as LKQ, a collection of once-privately owned salvage yards tied together with computers for instant access to any part within their system.
If you purchase the new imported tank I'd thoroughly clean it inside and use a high quality fuel tank sealer such as sold by POR-15---there are many good ones too. Cheap sealers are a waste of your time and shouldn't be considered.
You might also look for good condition salvaged tank which typically will be OEM and a lot less than Ford's new price. Of course I'd also clean and treat this one too as it seems you are having repeated issues with fuel tanks.
HTH
Old 06-07-2012, 06:48 AM
Thank you JWA. Good info, but;
My last tank was salvage and came out of Greenville SC which is a Keystone location. It had a puncture wound but no internal de-lamination. It cost the same as the "Action Crash" brand new tank. I'm thinking the OE Ford tank doesn't hold up well to modern road diesel.
Keystone does not offer a new tank for my 2002 and that's too bad. They have one for newer vans with a nickle alloy plating instead of the coating that's giving me grief. The stuff is swimming around in the fuel and getting sucked up to the pickup...thus blocking fuel passage. It then gets shredded by the pressure and bits of it take out the fuel pump. It seems the plated tank would be less likely to cause this recurring issue.
I've had floating POR skin inside an aluminum motorcycle tank before. I've used it on several other occasions with no problem before that incident, but I've had enough with this particular thing and really want a permanent solution.
Anyone know of a plated option? If not, I'll definitely apply a coating before the install. Some here have mentioned going to a radiator repair shop to have it applied. Whats the advantage over a self installed POR kit?
How about a plastic tank?
Old 06-08-2012, 06:36 AM
JWA's Avatar
JWA JWA is offline
Mr Gravity youíve covered most of the bases I would suggest---one step ahead of me---you've obviously put some thought into this!
Most ever fuel tank sealer Iíve known relied on good adhesion and was some sort of air cured polymer, typically used in aircraft tanks. Iím not familiar with the POR products as far as their sealers past the rust conversion surface preparations and certainly canít speak about too knowledgeably. Eastwood supply has a few sealers that I know have been used by the restoration guys for a long while.
A radiator shop probably wouldnít do any better a job than a motivated DIY however they could clean its inside very well, most likely some sort of hot wash, perhaps steam. From there a primer, etching agent or adhesion promoter for whatever sealer being used would most likely be an important step. Personally Iíd contact POR directly or cruise Eastwoodís site to see what they recommend. I canít imagine one of those outfits not having something suitable and long lasting.
Plastic tank would be great but are they available in a heavy duty size and shape that would also accommodate the Ford fuel pump set up? Thatís a great idea though!
Sorry I canít be more helpful!
Old 06-08-2012, 07:28 AM
I'm looking into having an aluminum or stainless tank custom made. In case there are any others afflicted with tank issues following this thread, I'll post back on my success or lack thereof at finding a fabricator.
Old 06-08-2012, 08:36 AM
JWA's Avatar
JWA JWA is offline
This would be great---could be others are looking for something similar.
There is a thread somewhere here on FTE about a custom made tank, possibly to contain fuel. I'll do some digging and post the link when I find it---might take a day or two, perhaps it would be somewhat helpful.
Old 06-08-2012, 08:55 PM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
It was discussed in Detail in this thread..........Another fuel tank delamination - Diesel Forum - TheDieselStop.com
Old 06-09-2012, 06:06 AM
Thanks for directing me to that thread on delamination. I somehow missed that one when searching for info before posting this thread.
I derived from all the reading that there is a plastic tank for the newer vans. I know that someone must have tried to retro fit one to an older van that's ailing with a crudded up system.
If no one posts as to the possiblity or impossibility of a straight bolt on or adapting my OE internal junk to the plastic tank, I think I'm headed down that rabbit hole.
Anyone know?
Old 06-09-2012, 10:28 PM
blageurt's Avatar
Ford E350 Diesel Tank Delamination - Pics - Diesel Forum - TheDieselStop.comHere is another of about 5 on the same topic.... If you join that Forum you can see alot more .....with other solutions people have come up with ..........
Old 06-10-2012, 08:51 AM
Thanks Blageurt.
I've been poking around the threads on that site for the last day or so.
Funny thing about every fuel tank thread on every site: Someone always mentions they are going to explore aluminum, stainless and plastic options...
and then the thread dies.
I really want to know if its true that the 2011 & newer vans have a plastic tank and what it would take to adapt it to my 02. I'm going to devote some time to this puzzle on Monday.
I'll post results here. Promise.
Old 06-10-2012, 09:45 AM
JWA's Avatar
JWA JWA is offline
This be an interesting update---hope its to your benefit and doesn't break the bank.
One would think someone, somewhere is making a compatible plasitic replacement tank even if its not an exact copy of the OEM.
I'm guessing if any such thread dies its due sticker shock of a custom tank or the interest alone dies off---certainly can't be because the tank heals itself!
Old 06-10-2012, 10:55 AM
blageurt's Avatar
These guys have a tank but it is expensive Titan
Old 06-10-2012, 12:08 PM
I found Titan's site early in my search. I did not see a van application mentioned but now see that it is mentioned in the text on the 40 gallon tank. Thanks! Its only $900 which is close to Fords retail for a new OE steel tank.
I just returned from the Ford dealership where I found a new van to crawl under. Sure looks, feels and sounds like a plastic tank.
I also came across a pickup cab/chassis awaiting a cube to be fitted. The top of the fuel tank was exposed between the frame rails. I assume the guts of the van and pickup fuel tanks are identical but will verify at the parts counter in the a.m. I've read that these tanks are less than $400. new from Ford.
for your viewing pleasure.
Old 06-10-2012, 12:53 PM
blageurt's Avatar
F-Series and E-Series are different.... The E 450-550's have the huge 50 gallon square tank in the back...Since you have a regular Van you need the 40 gallon centre tank .....
Old 06-20-2012, 05:42 AM
If I had the luxury of time, I would not have ordered a steel replacement tank. That's right, the symptoms have returned sooner than expected and a new replacement tank is on it's way. I will probably get it lined before install.
So the question of retro-fit-ability will need answering by someone else. Here are some bread crumbs you can follow.
What I learned:
1) 2010 and newer vans appear to have a plastic tank.
2) These newer vans are the same basic structure and I assume any tank that fits in post 10s will also fit in the space of pre 10s.
Info I was unable to obtain:
1) is the filler neck in the same location as the pre plastic steel tank.
2) will new tank straps and other fittings need to be purchased? Assume yes.
3) can the pickup (different part number) be made to fit?
4) will the hoses adapt? assume yes.
I had planned to order a new plastic fuel tank (which I found online for $311.00) and attempt to answer all these questions, but I am commuting 500 miles every week in this van and need it on the road "right now".
If all new internal bits, fittings and hangers need to be purchaced, this could still be an affordable option. If one considers the difference in the cost of the OE fuel tanks, converting to plastic is not likely to total much more money and will definitely end the flaking.
gear vendors ohioexwner Excursion - King of SUVs 0 02-05-2015 01:49 PM
Mustang gas tank dimensions? Drewski 2 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 01-09-2015 12:35 PM
Is the EEC-IV Computer hooked up to my C6 auto tranny? eagle275 1987 - 1996 F150 & Larger F-Series Trucks 4 10-30-2014 11:28 PM
Fuel line K9sicem 1957 - 1960 F100 & Larger F-Series Trucks 3 07-15-2014 05:41 PM
Need to buy gas tank valve badasssapper67 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 05-29-2014 08:20 PM
Tags
2004, 40, delamination, e350, ford, fuel, gallon, gas, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
