What is the replacement/upgrade for the FS-10 A/C compressor?
Old 06-06-2012, 04:45 PM
CountryBumkin's Avatar
CountryBumkin
CountryBumkin is offline
I decided it's time to fix my A/C system. Its been a couple of years now. I have the FS-10 A/C compressor on my 7.5L. For a long time I had a link to an A/C website that sold a replacement compressor for the FS10. The website explained that the problem with the FS10 design was that it did not have an oil sump. A slight leak (loss of oil) would kill the compressor quickly. There was another compressor model they recommended that was a direct bolt on that had a sump (at least as much of a sump as you can have on a rotary compressor).
I can't recall the model now and the website link isn't working. I guess I waited too long.
Has anyone heard about this - and what brand/model that compressor might be?
Thanks
Old 06-06-2012, 05:14 PM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
Ditto! The clutch on mine went out because the seals blew.
Old 06-07-2012, 10:12 AM
hivoltj's Avatar
hivoltj
hivoltj is offline
Nothing wrong with the FS-10 design, and as far as I know, there is no drop-in replacement that is a different design. Almost all compressors (not just Ford) don't have an oil pump, they rely on the oil suspended in the refrigerant.
Just replace it with a good (New not reman) stock one, make sure you change at least the Drier and orifice tube and have the rest of the system flushed.
Old 06-07-2012, 01:21 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
The only automotive compressors that I know of that had actual sumps were the old York single or twin-piston compressors used back in the 60s/70s
orve
02-28-2009 01:44 PM
bob1987f
10-07-2007 11:04 PM
NeXtras
15
03-25-2007 11:09 PM
1/2ton
08-08-2004 11:28 PM
RangerMikey2u
07-14-2003 08:16 PM
Quick Reply: What is the replacement/upgrade for the FS-10 A/C compressor?
