HELP!!! 1989 7.3 IDI NEED MORE HORSEPOWER - Ford Truck Enthusiasts Forums
Old 06-06-2012, 02:21 PM
blackbetty1989 blackbetty1989 is offline
blackbetty1989 is starting off with a positive reputation.
I have 89 7.3 it runs great and I love the truck but im a guy therefore I need more power! I have the fuel cranked up to 11, a banks wastegated turbo, and a holley fuel pump, what else can I do? thanks for any help
Old 06-06-2012, 02:28 PM
91dirtydiesel's Avatar
91dirtydiesel 91dirtydiesel is offline
91dirtydiesel is gaining momentum as a positive member of FTE.
Cam, more fuel, more boost, intercooler, properly timed, head studs, how deep you want to go? Why do you need more power?
Old 06-06-2012, 02:32 PM
Blu3 Blu3 is offline
Blu3 is starting off with a positive reputation.
Since you already have a turbo set up I would say get a bigger turbo and up the psi but the motor can only handle so much
Old 06-06-2012, 02:33 PM
well need and want are a fine line I guess itd be more need, I used to have a plug and play truck but I always wanted an old diesel now I got one and im trying to build it up to where my other one was, what would be the most bang for the $$$?
Old 06-06-2012, 02:39 PM
Head studs, cam, fuel on stock system maxed, intercooler and wastegate plugged you should be over 200 wheel horse easy. If you want to go deep and spend more then you can get much more power..........what's your budget
Old 06-06-2012, 02:43 PM
well right now not a whole lot, just bought 35" swampers and a new clutch and transmission for it, all the stuff you just posted how much would that run?
Old 06-06-2012, 02:47 PM
Best thing you can do then is re gear it. Bigger tires and stock gears aren't best for power. Prices vary, expect 300-600 for studs, 300+ for cam and springs, 150+ for intercooler, plug wastegate free, max fuel, free. Just make sure you have appropriate gauges for it.....can get hot quick
Old 06-06-2012, 02:55 PM
what size gears are you running with your bigger tires?
Old 06-06-2012, 06:34 PM
88 Ford IDI 88 Ford IDI is online now
88 Ford IDI is starting off with a positive reputation.
An injection pump upgrade is another upgrade to add to what 91dirty said. They are a lil bit more but are well worth it...
Old 06-06-2012, 06:55 PM
Quote:
When I had my lift on and 38.5s on I had 410s....and getting of the starting line was rough.
Old 06-06-2012, 08:34 PM
hookedondiesel hookedondiesel is offline
hookedondiesel is gaining momentum as a positive member of FTE.
Powerstroke and up the rear gears.
Old 06-06-2012, 08:54 PM
IHIDIferdy IHIDIferdy is offline
IHIDIferdy is starting off with a positive reputation.
Quote:
x2
There are some threads on hear of some guys building 7.3 for drag track, I suggest you do a search.
Old 06-06-2012, 10:35 PM
That would be 91dirty...
Old 06-06-2012, 10:48 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is online now
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Best of both worlds... 12v
Right now i would guestimate im around 200whp, and "satisfied" with it, for what it is. Big problem is fueling, take a look around and you will find that is a nut were currently cracking, tough nut though it is.
Easy stuff. Get a turbo pump, or turbo cal. max fuel on it. Set of stage 1 injectors, studs, wastegate to 15-20, 7.3 intercooler.
Not as easy: cam, different turbo, more expensive IP, mill pistons
Look up RacinNdrummin's and NMB2's builds and decide what you want to do.
Frustrated kent hittle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 02-11-2016 05:18 PM
1994 7.3 turbo injection pump on a 1989 n/a motor dsbyrd918 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 08-06-2014 10:17 PM
Fuel tank capacities of 1989 F350? wdsloot2 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-18-2013 12:28 AM
timing an idi 1989f250IDI Oklahoma Chapter 2 02-01-2013 12:26 PM
Turbo help 1989f250IDI General Diesel Discussion 11 08-14-2012 06:34 PM
Tags
1989, 2002, 73, 73idi, cam, diesel, differnt, fords, gain, horse, idi, money, performance, power, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
