wiper help - Ford Truck Enthusiasts Forums
wiper help
Old 06-06-2012, 11:45 AM
azertuche azertuche is offline
azertuche is starting off with a positive reputation.
wiper help
Hello,
I have a 1959 Ford F100 with a wiper transmission issue. Everything is in good order except the nylon bushings on the arms of the transmission. There is just some wobble where they fit on the motor clevis, which should be expected after 50 yrs. Any ideas, help on changing them out before I'm forced to make an upgrade on wiper? I don't see any way of getting them out without busting them all up?
Thanks,
Al
Old 06-06-2012, 03:59 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Welcome to FTE. A pic of exactly what you are talking about might get you more responses. The wipers will all come apart with a little patience.
Old 06-06-2012, 07:31 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Al; Welcome to the orphanage! Your timing on this question is good, as I was cleaning my wiper assembly up today in preparation for reinstallation. I was looking at the pivot points and decided they were in good condition. However the cam on my drive output shaft is worn to the point that I may not be able to adjust the park feature(looks like the adjustment was maxed). Maybe one our buddies here will have the source of parts for both our wiper problems
Now to answer your question, I think if you would go to a hobby store you could purchase some small bushing/tubing and sleeve your nylon pivots.
Just a thought!
I would be interested in your remedy to this problem.
Old 06-08-2012, 03:05 PM
Thanks for both replies. I will work on pics. Not sure if I am able to post attachments. Also, Wally I had thought about some type of nylon sleeves and washers. Just because the orginal are a one piece bushing I don't think they have to go back in that way. Have to find the right inside and outside diameters on the same sleeve.
Old 06-09-2012, 01:22 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
I don't see any way of getting them out without busting them all up?l
Pictures? I don't need to see any, because I know exacty what the problem is.
Ford did not supply the bushings, were only available with the wiper transmission arms. The way they are installed, it's impossible to remove them without breaking them.
This is not only the case with 1957/60's, but with most other FoMoCo vehicles as well.
There is no EZ fix, if there's a fix at all, because...where will you find a bushing that will work?
The only choice you have, is the same choice people had back then. Replace the arms.
Are the wipers vacuum or electric? The arms are not the same!
Old 06-09-2012, 04:09 PM
Refyred
Al,
[IMG]The only choice you have, is the same choice people had back then. Replace the arms.[/IMG]
Bill has a point, I'm not sure its your only choice! But if you would rather spend money and avoid the challenge of rebuilding your bushings.
You could search the net for part #s
B7Q-17540-A and
B7Q-17545-A.
These are the part numbers for the right and left arms of the electric wiper assembly. At about 25.00 each, thats only about a dollar a year for 50 year service life
Old 06-09-2012, 11:07 PM
1957/60 F100/1100 Electric Wiper Transmission Arms
There are no prices listed on the Ford Dealer Parts Locator System any longer. Where Teddy came up with the $25.00 figure, I dunno.
Do not be surprised if the prices are higher, because obsolete parts prices can vary wildly from one source to another. If you don't like the first price you're quoted, try another source.
B7Q-17540-A .. Right Wiper Transmission Arm / Obsolete
KINSEL L/M in Beaumont TX has 1 = 800-816-2894.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
YADKIN VALLEY MOTOR CO. in North Wilksboro NC has 1 = 336-838-4155.
NORTZ & VIRKLER FORD in Lowville NY has 1 = 315-376-3899.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 9 = 800-476-9653.
B7Q-17545-A .. Left Wiper Transmission Arm / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has 1 = 817-275-2381.
NORTZ & VIRKLER FORD has 1.
GREEN SALES CO. has 6.
CARPENTER NOS OBSOLETE PARTS has 9.
DON SANDERSON FORD in Glendale AZ has 18 = 623-842-8643.
Old 06-10-2012, 05:14 AM
2quickM100 2quickM100 is offline
2quickM100 is starting off with a positive reputation.
Thanks Bill, I was just looking for that information, you saved me the hassle. much appreciated.
Old 06-10-2012, 09:53 AM
Refyred
Yes it is unusual to see prices but sometimes they do.
Description: Seller: Miller Obsolete Parts View Profile
Price: $25.00 Phone: Show Phone Number
Quantity: 3 Email: Send Seller Email Inquiry
Condition: New / New Old Stock (NOS) Location: Binghamton, New York Map & Directions
Good luck in your quest.
Old 06-11-2012, 07:46 AM
Thanks to everybody who responded. You have been a great help. And so the quest begins.
Old 11-20-2014, 12:56 PM
johnnyidaho's Avatar
johnnyidaho johnnyidaho is offline
johnnyidaho is starting off with a positive reputation.
Vacuum assembly for 59 Ford F-100
I had originally posted in the wrong year truck so please bear with me.
I wish to remove the vacuum assembly on the firewall, see photo.
I removed the two slotted screws which held it to the firewall but the square stock which penetrates the fire wall and attaches to the arms doesn't appear to come off from inside the cab.
Does anyone have an exploded view or info on how to get this apart?
Many thanks in advance.
Old 11-20-2014, 07:24 PM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
Wally, I would think anything related to wipers in Southern Nevada would look like NOS under the dash. How often do you need them ,once a year?
Old 11-20-2014, 09:27 PM
Refyred
Gary.... I use my wipers for around 5 minutes, about a month after the rubber dry rots. or so it seems!
Johnny It looks like it should come out after removing arms 17566 &17567, the hole in the fire wall is fairly good sized? (this is the best picture I could find right off) I have the electric wipers so I'm not familiar with the vacuum motor but it looks like with a little wiggling it should fit without removing the short arms from the motor shaft.
Let us know what you find out.
Old 11-21-2014, 09:05 AM
Wally
Many thanks for the diagram, I can make that work.
Needless to say your firewall is in much better shape than my wife's but her truck belonged to her grandfather when he had the farm in Iowa and purchased it new. I just try to keep it going for her with my limited skills. Thanks again.
Old 11-21-2014, 02:05 PM
Refyred
Thanks for the kind words Johnny!
From the looks of your wife's truck you have done her Grandfather proud!
I understand the upkeep these trucks require, I have owned and worked my truck since 1970.
Wiper Transmission arm C1TB-17540-A Redworks 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-17-2016 04:48 PM
Windshield wiper transmission gaskets Gembone 1967 - 1972 F-100 & Larger F-Series Trucks 4 10-05-2015 09:12 PM
Wipers won't shut off Dalozsw Electrical Systems/Wiring 7 02-08-2015 07:19 AM
Windshield wiper removal AustinF250 1987 - 1996 F150 & Larger F-Series Trucks 8 08-07-2013 08:10 PM
79' F 150 wiper motor issues? Corpsman24 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-12-2012 03:53 PM
Tags
arm, b7q17545a, ford, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
