Need help replacing fuel filter in 1995 f-150 - Ford Truck Enthusiasts Forums
Old 09-27-2002, 10:04 AM
chromedome chromedome is offline
chromedome is starting off with a positive reputation.
I need help from start to finish replacing my fuel filter. I can't get the hoses off, I'm not sure if there is a switch or if I need a special tool please help. THANKS
Old 09-27-2002, 01:35 PM
924x2150's Avatar
924x2150 924x2150 is offline
924x2150 has a good reputation on FTE.924x2150 has a good reputation on FTE.924x2150 has a good reputation on FTE.
I haven't changed mine yet but have been reading about the repair. There is a fuel shut off switch( inertia switch ) under the dash on the drivers side, on the firewall, to the left of the brake pedal or behind the kick panel .You are supposed to start the truck and toggle the red button up with a screwdriver, if no button ,then pull off electrical conn. The gas pressure will be removed as the engine sucks up what is left in the fuel line, the truck will stall...then crank it some more to be sure. Disconnect your battery. The pressure will be gone and it should be safe to remove the filter. Remove fuelline-to-filter clips,one on each side...then you will need a special tool or equivalent to disconnect the filter from the lines. I have seen these tools in most good auto supply places, I not sure what you need though. The filter assy is held by two bolts remove those and you're done. Reverse the process to replace filter. I bought a Haynes repair book # 36058 and it has alot of stuff for the home mech. I wouldn't try to rebuild an engine using that book, but it helps with the small stuff.
Old 09-27-2002, 05:15 PM
kioolt kioolt is offline
kioolt is starting off with a positive reputation.
I keep on hearing people saying that the inertia fuel shutoff switch is on the drivers side. I've had the passenger side kick panel off years ago and seem to remember the switch being there. That's where it is shown in the Helm's manual.
Besides the location of the shutoff switch, the rest of the instructions given in the first reply is essentially correct. I see no reason to disconnect the battery after depressurizing the system. I have changed my filter three times on my 93. I usually unplug the fuel pump relay and crank the engine over. I think this is an easier approach.
Old 09-30-2002, 12:24 AM
924x2150's Avatar
I think the last guy has a point. I went out to look for the switch and struck out. Look in your owners book and try to find the fuel pump relay. Pull it and the pump will die. I need to find that switch too, If someone decides to have a fender bender with me, I still might have a driveable truck, unless the inertia switch pops off. If it can't be found the truck will be stuck.
Old 09-30-2002, 01:19 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
I've been in two accidents with the same truck, one i slipped on a brige in snow and rear ended a guy pretty hard, the second I was hit from the passanger side at 50 mph, both times my engine was still running after the accident, good ol inertia switch.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin
Old 09-30-2002, 03:36 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
The inertia switch is on the passenger side behind the kick panel on 92-96 models.
1995 F-150 Supercab XLT 155" 4x4 M5OD 302
1986 F-150 4x4 NP435 300
Old 09-30-2002, 07:56 PM
WB9PRG WB9PRG is offline
WB9PRG is starting off with a positive reputation.
On my 1996, the inertia switch is on the passanger side behind the side panel (to the right of the passangers right leg). The inertia switch has a red piece on top.
When I change the fuel filter, I just remove the connector at the bottom of the switch and turn the engine over to run the gas pressure down.
Then, I use the "quick disconnect tool" wich is a little plastic round device that slips between the fuel line and the fuel filter to enable me to get the fuel line off of the filter.
I bought the "Powerbuilt" fuel line quick disconnect set part #648424
at checker auto for 11 dollars.
The 5/16" size will do the job.
There is a metal version of the quick diconnect tool available as well.
Good luck,
Gene
Old 10-01-2002, 06:26 PM
924x2150's Avatar
hEY mUSTANG gt22
i WOULD THINK ABOUT FIXING YOUR INERTIA SWITCH. sOUNDS LIKE IT SHOULD HAVE SHUT OFF YOUR FUEL.MY KIDS FRIENDS WERE RAISING HELL BY POUNDING ON THE SIDE OF CAR TRUNKS WITH THEIR FISTS SO THE INERTIA SWITCH WOULD KILL THE FUEL SUPPLY. WHEN SOMEONE WAS GOING TO CHASE THESE KIDS, THEIR CAR WOULDN'T START.
Old 10-02-2002, 10:50 PM
JScott488 JScott488 is offline
JScott488 is starting off with a positive reputation.
I changed my fuel filter tonight. I pulled the fuel pump relay, started the truck, it died. I cranked it over for about 20 seconds to make sure the pressure was relieved...It wasn't. I got one end of the line off the filter and took about a gallon fuel bath. Then I ended up breaking the little clips on the inside of the coupler on one of the ends...I've got the outlet line held to the filter with bailing wire until I can get a new clip. Ford had some odd ideas for clips...............
Jon kc0ded
1995 F-150 XLT 4x4 302 AODE, 31X10X50 Goodyear
1992 Ford Tempo 5spd 2.3
Old 10-02-2002, 10:54 PM
Oh yeah, and If I saw a bunch of kids beating on my truck, I'd shoot first and reset my inertia switch later.
Jon kc0ded
Old 10-03-2002, 01:37 AM
mike_v2v98 mike_v2v98 is offline
mike_v2v98 is starting off with a positive reputation.
93 idi 7.3l fuel filter flickering/smoke at start up gbeach Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 09-20-2015 11:20 PM
Help Please - Fuel Filter Change waggdr 6.7L Power Stroke Diesel 17 10-16-2014 11:20 PM
Fuel Filter Replacement rcnease Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 07-31-2014 08:57 AM
1990 f250 fuel filter countryshiz87 1987 - 1996 F150 & Larger F-Series Trucks 4 01-13-2012 01:46 AM
Are there two Fuel Filters? wfmcbride Bronco II 8 10-17-2006 08:21 PM
Tags
1995, 1996, 92, disconnect, f150, filter, ford, fuel, line, location, pump, replace, replacing, size, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
