TIMING CHAIN - Ford Truck Enthusiasts Forums
TIMING CHAIN
Old 06-05-2012, 03:21 PM
MarauderV8 MarauderV8 is offline
MarauderV8 is starting off with a positive reputation.
TIMING CHAIN
Hi folks, i need your help!
Have to change timing chains at a F150 5.4 from 2005.
Iīm in possession of an original Ford workshop manual. But i canīt understand, how i have to find out the right timing marks. On the cam phasers are two marks. one is only a dash, the other one is like a ENTER button from a keyboard. Which is the right? Furthermore, where is the reference point at the cylinder head???
Please give me an answer as soon as possible!
Thank you so much in advance!!!
Old 06-08-2012, 01:52 PM
jrroth jrroth is offline
jrroth is starting off with a positive reputation.
The cam phasers only go on one way as there are dowel pins. Before you start - rotate the engine to TDC. When you take the timing cover off - there will be a dot on the crankshaft sprocket at around the 7 oclock position as I recall. The reference marks on the cam phasers will be at 11 oclock for the passenger side and at 1 oclock for the drivers side. The dark links on the chains go at these reference points (cam phasers and sprocket).
In just did mine so let me know if you need any more info.
which timing chain? and base timing question. Jon351m 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 03-23-2012 07:57 AM
Timing Chain dfboothe 1999 to 2016 Super Duty 6 06-23-2010 10:50 PM
4.6 romeo timing chain alignment Jim88554 Modular V8 (4.6L, 5.4L) 5 11-19-2008 08:15 AM
Where are the "copper" marks on my timing chains? geoaigel Modular V8 (4.6L, 5.4L) 15 02-15-2006 09:26 PM
setting timing (chain) porkchop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 02-10-2002 02:35 PM
Tags
2008, 46l, 69, cam, chain, crankshaft, dot, f150, ford, index, installing, marks, matter, phasers, timing, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
