96 F150 Brake Problems - Ford Truck Enthusiasts Forums
Old 06-05-2012, 02:10 PM
pistolhunter pistolhunter is offline
pistolhunter is starting off with a positive reputation.
I have a 96 F150 4x4 with a 5.8l Engine, Automatic w/ OD and Cruise Control.....My Brake and ABS light comes on almost immidiatley after driving for a min or two.....when it does the pedal gets hard and I have little brake power....also, the rear brakes will lock up.....
I have replaces a couple hard lines, Calipers, hoses, pads, shoes, wheel cylinders, spring kit, Drums, rear ABS senser, master cylinder and all new fluids....bleed them well....no changes in this problem...anyone have any ideas cause I am all out and at the end of my rope...
Thanks
Old 06-05-2012, 04:15 PM
RIKIL's Avatar
RIKIL RIKIL is offline
RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.
Thanks
Have you pulled any of the codes?
Old 06-05-2012, 04:22 PM
No I dont know how
Old 06-05-2012, 04:32 PM
RIKIL's Avatar
Looks like there is a lot of info here - http://www.ford-trucks.com/forums/11...an-eec-iv.html
There are a couple of ways to do it. Try one and if you have trouble, let me know.
Old 06-05-2012, 04:36 PM
RIKIL's Avatar
I'll also add...I have pulled the codes via the jumper method and while it works, I think it is just a lot easier to spend $40 and get a code reader from an auto parts store. When I read the codes I connect my reader, push a button, walk away, and when I get back it's done.
Old 06-05-2012, 04:39 PM
Thanks, I will try that.....I was going to let Autozone scan it, but they said their reader only looks and Check Engine Codes and will not see Brake codes....not sure if thats true or the guy doesnt know....but I have put enough money in the brakes, another handfull wont break me I guess....I'll let you know what I find out
Old 06-05-2012, 04:52 PM
RIKIL's Avatar
AFIK there is only one place to pull codes from these vehicles. The brakes (ABS computer) should report back to the EEC-IV. Sounds like the only thing you haven't replaced is the ABS computer (should be behind the glove box). Not sure if they ever go bad or not.
Old 06-05-2012, 09:36 PM
I've looked on-line and all the code readers will only scan ABS codes for 1997 and newer with 4 wheel ABS...mine is a 96 with 2 wheel ABS on rear only.....anyone have any other suggestions as to whats left that can be bad I can replace?
Old 06-06-2012, 12:13 AM
290 290 is offline
290 is starting off with a positive reputation.
Im having a similar problem and what fixed the trouble light for me was replacing a bad connector for the ABS/VSS.
1992 Rear ABS Brake Problem KDCS 1987 - 1996 F150 & Larger F-Series Trucks 7 07-10-2013 12:16 PM
96 f150 ABS Issue pistolhunter 1987 - 1996 F150 & Larger F-Series Trucks 6 02-22-2011 08:02 AM
1985 f150 straight 6 light truck brake problem mattthegreat 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 01-17-2010 05:27 PM
1997 Ford F-150 Brakes will not pump up lmoore2422 Brakes, Steering, Suspension, Tires, & Wheels 3 10-25-2008 08:22 AM
02 f-150 ABS lIssues windstar99 1997 - 2003 F150 3 08-06-2008 12:42 AM
Tags
1996, 46l, 96, 97, brake, f150, ford, issues, problems, shooting, system, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
