Tailgate Adjustment Question - Ford Truck Enthusiasts Forums
Old 06-05-2012, 01:45 PM
piratius's Avatar
piratius piratius is offline
piratius is starting off with a positive reputation.
Hey guys, I feel silly asking this question, but...
How do you adjust the latch on a styleside tailgate? I sprayed the latch hinges/mechanism and the two end units with penetrating oil and it freed up really nicely, but the end pins won't pull back far enough to allow the brackets to clear, so the tailgate won't lower.
I have it off the truck currently, was going to clean it up/paint it before I installed it, and remembered that it was a PAIN to get it off the old bed because of this exact problem
Any advice on adjusting the darn thing?
-Brad
Old 06-05-2012, 02:19 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
Are both hinge rods hooked to the latch. Sometimes the plastic clips holding them in the latch break and then one rod pops out. If they are, it could be that the latch itself bent and now won't open up far enough to engage the hinges all the way.
Old 06-05-2012, 02:26 PM
piratius's Avatar
The two plastic clips on the handle (latch?) end are fine. I haven't pulled apart the outsides to see if they're still intact. There seems to be about 1/2" of play between where you start pulling and when the latches start moving.
-Brad
Old 06-05-2012, 05:21 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Sometimes you have to take the rods out and put a bend in them to get enough pull out of them to release the latches.
Old 06-05-2012, 09:10 PM
piratius's Avatar
That is also an excellent suggestion. I'm going to take the latch out tomorrow morning and see if it was bent by the previous owner. Judging by how stiff/frozen the mechanism was when I bought it, it wouldn't surprise me if he'd just kept yanking on it and bent or broken something.
Putting an extra bend in the rods also seems like a good idea if all else fails - should I heat it with a torch until it's glowing, then bend it and quench it? Or do you think bending cold is fine? I suppose the easiest way would be to heat it, un-bend the end that goes through the latch on the side, and then re-bend it about 1/4" closer in.
-Brad
Old 06-05-2012, 09:24 PM
Blue and White Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
I'd unscrew the handle mechanism and pull it all out for a look see. In addition to the above suggestions, you may be able to adjust the catches on the side out a little so less movement of the bolts is required to open it.
Old 06-05-2012, 11:01 PM
piratius's Avatar
Quote:
How do the catches adjust? If you're talking about the two "L" brackets mounted to the sides of the tailgate opening, that won't work for me - the bolts move so little that you can't even slide a bracket into place with it off the truck
-Brad
Old 06-06-2012, 09:44 AM
Glad Mark posted the "bending" of the rods suggestion as I did forget that. I know my tailgate rods had slight bends in them and they barely open enough to get the latches open.
Old 06-06-2012, 12:45 PM
brian1080's Avatar
brian1080 brian1080 is offline
brian1080 has a good reputation on FTE.brian1080 has a good reputation on FTE.
new ones are pretty cheap through Bronco GY. I just replaced both of mine since one was broken. Doesn't take much time to do either.
Old 06-06-2012, 01:33 PM
piratius's Avatar
I may just replace them in the near future.
HOWEVER, I was able to modify the handle assembly so that both of the latches would disengage enough to allow the body latches to clear.
What I did was grind out a tiny bit more of the handle assembly - it's got a little "dimple" in the arm where the handle contacts the cam assembly.
You can see what I did - I basically doubled the width of the little dimple, allowing the arm to move a LOT further. Pretty quick & easy - much faster than disassembling all the latches to get the rods out just to bend an "S" into them.
I hope this helps someone in the future. I do need a pair of those plastic clips now though!
-Brad
Old 06-06-2012, 08:00 PM
77 1/2 F250 77 1/2 F250 is offline
77 1/2 F250 is starting off with a positive reputation.
I replaced the plastic clips in my 77 tailgate with soe from the help section at the parts store. The ones I used were labelled as door clips for mid seventies Ford cars. They have been working for pretty close to fifteen years now.
Robert
'08 f250 tailgate won't latch RancherJV 1999 to 2016 Super Duty 2 09-25-2016 08:32 PM
Tailgate Handle Adjustment njsubi86 1999 to 2016 Super Duty 1 06-24-2015 03:57 PM
'79 Bronco Tailgate Won't Latch Wally Moore 1978 - 1996 Big Bronco 14 11-05-2012 05:07 PM
88 F150 tailgate latch broken. I need help! Ford1988Trucker 1987 - 1996 F150 & Larger F-Series Trucks 3 08-02-2010 09:25 PM
Tips to Fix a Tailgate Latch Rod? jasond5150 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-06-2008 10:48 PM
Tags
1999, 351m, 77, 90, adjust, adjustment, big, f150, ford, latch, mechanism, questions, tailgate, trucks, videos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
