Horrible towing fuel mileage . - Page 6 - Ford Truck Enthusiasts Forums
EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
  #76
Old 04-24-2014, 05:47 PM
Texas74 Texas74 is offline
Texas74 is starting off with a positive reputation.
MPG Not Bad, but
I have a 2013 Ecoboost 4x2 with the 3.5 rear end and 28,000 on the odometer. My MPG ranges from 10 to 15 when towing a #7,300 Airstream. I get about 19 MPG when not towing driving a combination of city/highway.
Of course there was a tailwind when the 15 MPG.
  #77
Old 04-28-2014, 04:17 PM
donovan donovan is offline
donovan has a great reputation on FTE.donovan has a great reputation on FTE.donovan has a great reputation on FTE.donovan has a great reputation on FTE.donovan has a great reputation on FTE.
Not great not Bad
Look 7.6mpg towing a TT is not bad. TT are about the worst whenit comes to wind resistance. My V10 gets about 8 Towing my TT, MyDiesel gets about 10. I have used other trucks to pull thesame trailer and I get around the same mileage, wow. Its not just the truck but the driver andthe trailer and conditions. I would not jump to a diesel thinking you're going toget better mileage. This gas engine and the turbo are working veryhard to pull two bricks through the air. If you tow a lot think about a diesel but if you don't DON'T.<o></o>
  #78
Old 04-29-2014, 05:51 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
Originally Posted by daytomann View Post
I'll go ahead and say it. Ford's marketing on EB is fraudulent. V8 power with V6 MPGs is a joke.
They've sold well because guys test drive them and end up with a woody due to the power. They then think they are going to be able to consistently USE that power and get great MPGs. Then people want to get into towing with a V6 and get good MPG? Seriously?
Our 5.0 is siting at 17.7 in town. When I tow our 4500lb boat/trailer I'll get 10-12 over 160 mile jaunts. Depending on conditions.... I dont tow over 65mph and I do a fair amount of manual shifting when I tow.
Another thing is that I'll never get why so many people tow at 70-75 mph? What are you thinking?
Fraudulent? Really? You must be one of the guys who bought a 6000 LB 3.73.1 geared truck based on a TV ad and expected 30 MPG's.
All the data is there on Ford's site. Towing guides, comparison data and the window sticker says the rest. All it takes is a little research effort to make an educated decision.
  #79
Old 05-29-2014, 07:45 AM
johndeerefarmer johndeerefarmer is offline
johndeerefarmer has a good reputation on FTE.johndeerefarmer has a good reputation on FTE.johndeerefarmer has a good reputation on FTE.
I tow two Polaris RZR's on a 24' heavy duty tandem axle equipment hauler. At 70 mph I get 8 mpg with my King Ranch with 6.5' bed and max tow.
I had a 2013 F250 Powerstroke- it was 2wd and a Super Cab. I only got 11mpg.
So from the worst possible configuration for a F150 (heaviest) to the best configuration for fuel economy for a diesel the difference was 3 mpg. Gonna be hard to justify a diesel with only 3mpg difference
  #80
Old 05-30-2014, 06:46 AM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
I tow a two place steel snowmobile trailer in the winter and have seen a high of 11mpg and a low of 7.5mpg
Speed plays a big factor in these mpg's.
  #81
Old 08-21-2014, 08:22 PM
juniorsdaddy's Avatar
juniorsdaddy juniorsdaddy is offline
juniorsdaddy is starting off with a positive reputation.
If you pull a travel trailer with any gas burner you can expect single digits. The EB is much better than other gas burners I have tried. With my 2011 EB if I keep it around 60 10mpg is no problem with my 6000# TT. If you try to run 70 the mileage will be around 8. I have a 2005 4.6 v8 and I would jump up and down if it got 8-9 pulling the same trailer. It is more like 7.
  #82
Old 11-30-2014, 03:57 PM
KCBS Smoker KCBS Smoker is offline
KCBS Smoker is gaining momentum as a positive member of FTE.
I tow the trailer in my sig and get about 9 mpg in the hills of northern VA. I keep it around 65mph on the interstates.
  #83
Old 12-02-2014, 06:33 AM
tseekins's Avatar
My neighbor has an older F-150 with the 5.4 3V and he gets about 6-7 pulling his TT which weighs about 7500 lbs.
My other neighbor h as a 2011 Silverado and pulls his TT and he doesn't do any better. The ecoboost loaded or unloaded will out work both of these engines.
  #84
Old 02-12-2015, 06:43 PM
KP1001 KP1001 is offline
KP1001 is starting off with a positive reputation.
Quote:
Originally Posted by Psyberbilly View Post
Picked up my new SuperCrew 4x4 w/ 3:55 and the short bed a few weeks ago , runs like a champ . Last week I made a 150 mile trip to pick up a 3926 lb travel trailer . On the trip up , I got 21.2 mpg running 70 up the interstate . On the way back on the same route , running @ 60 , I got 7.5 mpg. I took it into the dealer for another issue ( parking brake cable , which they fixed ) and asked the service writer about the mileage issue . His reply was that I "miscalculated " and for me to not pay any attention to the "instant mileage " display ( which I don't use anyway ) . Using my trip meters as well as manually calculating , I came up with the same #s .
We were scheduled for another short trip this weekend so I told him I would monitor the situation again and get back with him on Monday . A 200 mile trip , and a resounding 7.6 mpg . I went back in yesterday evening , he looked in his computer and said " Ford has no records of this problem , so just monitor it.... " I really didn't like that answer , so I went and talked to my salesman , and he said that didn't sound right to him either , and " I'll go talk to the service writer ... " While he was gone , I was talking to the guy in his office , who had purchased basically the same truck as mine @ a week before me , his truck has @ 500 miles less than mine on it ( mine is at 2,900 ) . He just got done with a 500 mile trip pulling a 3,000 lb boat and averaged 16.5 mpg .
The salesman returned and said the writer told him that " Ford does not even consider fuel economy issues until after 5,000 miles " . The truck does not run poorly , pulls the load with no problem , it just drains the tank to fast .
I could understand waiting out a 15-25 % discrepancy , but this big of a differential obviously indicates something is not right and I don't see why I should have to choose between refraining from doing what I bought the truck to do , or pouring my hard earned $$ into the tank until I each some arbitrary mileage point . Has anyone encountered this , have any ideas what could be causing this and where to go from here ?
Try running 100% gas. I have a v10 and was as disappointed in it as you were with your ecoboost and it was because of that ethanol crap.
  #85
Old 02-12-2015, 06:58 PM
Anybody know why they dont put the ecoboost in superduties?
  #86
Old 02-12-2015, 07:57 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Quote:
Duty cycle in a SD is much different. Those turbo's would be working a lot more.
  #87
Old 02-13-2015, 09:37 AM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
There are lots of rumors of what the future holds for super duty engines, and EcoBoost 3.5 or EcoBoost 5.0L engines are always brought up. I think some version of that will happen eventually, but may take a few years.
  #88
Old 02-14-2015, 05:42 AM
Atlee Atlee is offline
Atlee is gaining momentum as a positive member of FTE.
Weight only comes into play when in stop and go city type traffic.. Weight doesn't penaltize you much when driving steadily on highways.
Any enclose trailer, especially a travel trailer will kill towing mileage due to the huge relative flat surface you are towing.
That's also why pulling a heavy boat usually doesn't have the same penalty that pulling a lighter TT does. A boat cuts through the air better than a flat faced TT.
Quote:
Originally Posted by EcoboostKev View Post
I average 10-10.6mpg pulling my 32' 7500lb camper with the cruise set between 60-65mph. Something isn't right if your only getting 7.5mpg with only 4000lbs in tow.
  #89
Old 02-14-2015, 06:13 AM
A 5k boat on trailer will normally get better mileage than a 5k travel trailer. The boat will tend to cut through the air better. A TT has a huge relatively flat front. It will cost in general another 1.5 to 2.5 mpg.
Quote:
Originally Posted by vans View Post
Normal Driving= 17mpg= drop down during cold weather
I'm getting 14 pulling my riding lawn mower on small trailer, 70 mph on highway
I'm getting 12 pulling my boat , estimating around 5000 lbs, highway miles
  #90
Old 02-14-2015, 06:20 AM
If driving under 65, and if the trailer brakes aren't dragging any, and if the trailer axles are in alignment, then 7.5 avg is a little low for the ecoboost.
I'm averaging about 10.5 with my trailer. Sometimes a little more, and sometimes a little less. And my 3.5 ECO is probably averaging about .5 mpg better than my old 5.4L did.
It's also averaging about 1 mpg better in non pulling, local driving.
Quote:
High Altitude Areas Regeneration Issues while Towing? Homebrewer29 6.7L Power Stroke Diesel 18 09-05-2016 03:26 PM
Friendly Ford Sucks Map Man 1 6.7L Power Stroke Diesel 11 07-03-2015 06:52 AM
Oh look! Another stealership post! Armycop 6.7L Power Stroke Diesel 48 12-19-2014 01:46 PM
Nitrites in Coolant j klug 6.7L Power Stroke Diesel 12 09-12-2012 12:11 PM
2005 6.0 edge programmer fried my ficm fordfreak05 6.0L Power Stroke Diesel 10 06-23-2012 12:29 AM
Tags
35l, diesel, eco, economy, f150, f250, ford, fuel, gas, milage, towing, trailer, travel, turbo, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
