"Torque PRO" OBD software for Android tablets and phones - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-23-2013, 05:03 PM
enormiss's Avatar
enormiss enormiss is offline
enormiss has a good reputation on FTE.enormiss has a good reputation on FTE.enormiss has a good reputation on FTE.
No gauges but factory (incl. trans temp & volt) & now torque app
EGT will be added but not anytime soon
Would you set alarm points for the EBP, ICP, IPW if so what would they be?
Just interested in 6 cause they are easy to view on one screen.
Preparing for my first camper pull with this vehicle and will not be fiddling with the tablet.
But do want to keep an eye out for poss issues...
Thanks!
Old 09-23-2013, 05:21 PM
ScaldedDog's Avatar
ScaldedDog ScaldedDog is offline
ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.
I wouldn't set alarm points for any of the things you mentioned, as there are no real "bad" values for any of them, or at least none you're likely to see in the wild. I use them primarily for learning.
The voltmeter and tranny temp gauge on your dash are worse than worthless, as they pretend to display relevant values, but don't. Your voltmeter needle may as well be painted on the dash, and your tranny has gotten hotter than you want it to be well before the tranny temp gauge moves off its normal settings.
Mark
Old 09-23-2013, 09:21 PM
landshark69's Avatar
landshark69 landshark69 is offline
landshark69 is starting off with a positive reputation.
torque and trany
anyone know if torque or torque pro can read transmission codes ?
Old 09-23-2013, 09:58 PM
Jesser02EX's Avatar
Jesser02EX Jesser02EX is offline
Jesser02EX has a great reputation on FTE.Jesser02EX has a great reputation on FTE.Jesser02EX has a great reputation on FTE.Jesser02EX has a great reputation on FTE.Jesser02EX has a great reputation on FTE.Jesser02EX has a great reputation on FTE.
Quote:
Not that I've seen in the config...
Old 09-24-2013, 04:01 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Quote:
Originally Posted by jhobbs26 View Post
here's my screen shot with a WOT run.
http://www.powerstroke.org/forum/att...reenshot-1.jpg
Your torque converter is slipping, I usually get a reading of 0 or 1.
Your EBP reading is confusing. The best I can come up with is Pascals X 100
Old 09-24-2013, 06:18 AM
jhobbs26 jhobbs26 is offline
jhobbs26 is starting off with a positive reputation.
I updated the EBP PID formula to read actual PSI, after this screen shot was taken.
From all the screen shots available from other users on the other forums, mine looks like everyone elses?
Old 09-24-2013, 09:38 AM
Tugly's Avatar
Those are stock numbers on a healthy truck.
The TC slip is not being picky. If you have that while cruising, I'd be throwing spare change and dollar bills in a jar for a transmission in the future (no rush).
Old 09-25-2013, 05:37 AM
Would a fluid flush make any improvements? It is on my to-do list. Since i mainly use the truck to pull my 28' enclosed, and i've only got to race 3 times since buying this truck, the tranny flush will be on order before next race season
Old 09-25-2013, 06:23 AM
Tugly's Avatar
I know very little about transmissions, but I know slip = heat = wear. Maintaining the transmission is always good, so that's a good place to start... then check your slip again.
Old 09-25-2013, 05:35 PM
enormiss's Avatar
Is there a thread/discussion anywhere that shows typical/normal readings for all the gauges?
Should there be no converter slip towing?
Thanks
Old 09-25-2013, 05:50 PM
ScaldedDog's Avatar
It shouldn't slip when it's supposed to be locked, but are you certain yours was supposed to be locked when that screen shot was taken? If the difference in speed between the torque converter and input shaft really reached 2145rpm when the TC was locked, I think you'd know. Your tranny temp sure wouldn't stay 128*F for long if that was the case.
Be careful putting too much stock in Torque without verifying the values with a better tool. You can edit the Torque formulas to produce any value you want, and some of the Ford-specific ones were wrong right out of the box.
My guess is you have no problem, but no one on here can tell you if you do or don't, based solely on the data from that screen.
Mark
Old 09-26-2013, 05:01 AM
its been too long since i ran that to remember what gear i was in when the screen shot was taken, i'm pretty sure it was in 4th @ WOT. The 2145rpm was taken while the truck was stopped at a stop sign. Normal driving 60-70 mph the TC slip shows around 0-30rpm of slip.
Which PIDS are wrong? I know the EBP is, i've corrected the forumula to register true PSI, but i was unaware of any others being wrong.
  #28
Old 09-26-2013, 07:20 AM
Tugly's Avatar
ScaldedDog was referring to anything that tries to register actual torque... if I am catching his meaning correctly. "Toque Pro" software implies it will read just that... prompting anyone with experience to say "A torque meter? From OBDII data? Pshaw."
The screen I looked at showed a 12 RPM slip, with the hi/lo readings below it. I know from my experience with AE that the only time you'll see a slip reading that low is in TCLU... but it really should be zero (plus or minus 1 or 2 for error). That would be what I call a lock-up with the drive shaft.
  #29
Old 09-26-2013, 11:40 AM
ScaldedDog's Avatar
Rich, I don't understand your comment about mine.
Jhobbs, see if you can find another of my posts on the subject. It was one of the temp formulas, but I don't remember which on. Also, see if you can monitor the status of the TC solenoid in Torque.
Mark
OBD Link MX problems **Solved** bigb56 1999 - 2003 7.3L Power Stroke Diesel 3 12-18-2016 04:09 PM
Torque Pro FAQ Jaime74656 1999 - 2003 7.3L Power Stroke Diesel 59 11-12-2016 09:25 AM
Torque Pro- Oh No! ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 1 05-17-2016 05:06 PM
Transmission Fluid Temp Custom PID for TorquePro Mike8253 Modular V10 (6.8l) 6 07-06-2014 04:37 PM
Wireless OBDII - MPG Gauge for $12 jeffnick 1968-2013 Full Size Vans 4 03-26-2014 07:26 AM
Tags
2001, 2003, 73, adapter, android, bluetooth, diagnostics, explorer, ford, obd, obd2, obdii, pid, spec, sport, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
