Crew Cab Interior Rejuvination Project
#186
#187
I made some mistakes the paint is holding up fine but then again its not getting used much. it has scratched off in some spots where the seats rubbs but i also attribute that to the can method not laying down a thick enough layer and the paint being more for vinyl than plastic. also when the factory paints these pieces like the dash which is painted it has a thick layer.
Definitely use the adhesion promote.
if i were to do it again i would change the paint i used
i would try SEM or Color Bond instead which is made specifically just for that
the duplicolor is fantastic on Vinyl for sure, i sprayed the old seat covers and it was like it soaked the color into the material. with these plastic pieces some are the hard plastic that can snap( those tend to be painted so be carefull with your prep it will melt off old paint and make a mess) and others plastic like the kick panels are the more flexible type. I would go COLOR BOND this time around
#188
Good to know, thanks. I used color bond for my 95 and on my 08 console and it has held up great on the console hasn't even rubbed off and i just did 3 average coats. I would like to find the Ford Harley black from color bond but i couldn't figure it out so i went with a different ford black and its not quite what i was looking for but it still looks great i think i went with color code 357 i would have to check.
#189
#191
Troy Bauer
26
12-09-2017 12:04 AM
cjohn2000
02-17-2011 10:06 PM
bobfl
04-25-2002 09:33 AM
