360 timing issues
Old 06-04-2012, 10:40 PM
FordmanShane's Avatar
FordmanShane
FordmanShane is offline
360 timing issues
Hey there fellas ive had the ford truck blues for a wile I can figure out why this old 360 wont run, miraculously I got the ol girl to go around the block, but when I push on the throttle she wants to die... It seems the problem lies in timing... I need second opinions on this I marked the harmonic balancer at 0 with a white marker when I put the light on it the mark is actually jumping around isn't it supposed to be consistent? your 2c is welcome..
Old 06-05-2012, 11:41 AM
Nighteyez's Avatar
Nighteyez
Nighteyez is offline
Well, I doubt the timing chain is jumping around to cause the white mark to do so. Only other thing I can think of is distributor. Something causing the spark plug not to fire at the same exact time. However, I don't know what would cause that, maybe a weak coil? bad ground? Grasping at straws here.
Jim
FordmanShane
06-04-2012 10:53 PM
elizabethvan
10-15-2011 10:24 AM
cowboyup11
02-02-2009 02:26 PM
my69ford
06-01-2006 12:10 PM
68 250 Flareside
10-27-2005 02:33 PM
Quick Reply: 360 timing issues
