Pinging
Pinging
Ok all I am going nuts, my 88 F250 with 460 Has started pinging badly now that the temps are rising (summer) I am out of ideas. I have done cap, rotor, plugs, wires, and coil. timing is set to 10deg (spec) fuel filter and air filter are also new.
Any Ideas as to what I am missing?? It runs fine in the mornings but gets worse as the outside temps go up. If I run 91 octane fuel it all but stops pinging and generaly runs better.
21: Engine Coolant Temperature (ECT) Sensor Out Of Self Test Range
41: System Indicates Lean
The lean burn is the cause of your pinging, and I suspect the cause of the lean burn is a faulty Coolant Temperature Sensor telling the computer the engine is a lot hotter than it really is.
Here is what I'd do:
Get a new engine coolant temperature sensor and install it. Just remember that these trucks have two; one for the computer and one for the dash gauge. You'll want the one that has a two-pin connector on it. The dash sensor just has a single terminal pin.
Disconnect the battery for 15-30 minutes and drive it around for a while. If the pinging is gone - call it fixed. If the pinging is still there, pull the codes again and we'll go from there.
EDIT: Also get yourself a fuel pressure tester and check the fuel pressure. You should have 39.5 PSI key on engine off, a few PSI lower while idling, and 39.5 PSI if you snap the throttle wide open while running.
Hey one of my friends has a 1992 f150 4.9 and it surges any ideas. i cleaned the throttle body and he put new plugs and wire cap and rotor O2 and the temp plug at the front of the motor. it runs fine when your going but when you stop at a light it surges bad and sometimes dies...?
Tony Ricci
15
11-26-2018 12:14 PM
Chuck999
1997 - 2003 F150
03-05-2013 02:20 PM
