6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 Super Duty F250 6.4 L Diesel Problems
Old 06-04-2012, 07:52 PM
jraquel's Avatar
jraquel
jraquel is offline
Hello All,
I have been having problems with my 2008 F250 6.4 L Diesel. Two radiators so far, and now, one day after the second radiator was installed, this past Saturday, June 2, 2012, I had 2 quarts of oil in my radiator.
The Turbo discharge hose blew off 3 times right after the radiator was installed. Cleaned and washed it and drove it 150 miles before the oil in radiator problem was noticed.
Went by my dealer and they told me that it was either the EGR Cooler or the Oil Cooler. I may be wrong, but the EGR Cooler does not have oil going through it or does it?
Is there anything else other than the Oil Cooler that can leak oil into the coolant system?
Dealer told me it could cost between $900.00 and $2500.00, depending on what was wrong, So I am a little concerned about what they said about the EGR Cooler leaking oil in the radiator. Is this possible?
Thanks and Have a Great Day,
jraquel
Old 06-11-2012, 02:13 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.4L Power Stroke Diesel forum.
Old 06-11-2012, 05:45 AM
senix's Avatar
senix
senix is offline
Received 1,410 Likes on 1,006 Posts
time for a new dealer. No oil in the EGR cooler. However the oil cooler itself has coolant that goes thru it.
Is this motor still under warranty?
Sounds like some weak work on thier part.
Old 06-11-2012, 06:59 AM
jraquel's Avatar
jraquel
jraquel is offline
senix,
Thanks for the reply,
Motor not under warranty. I heard Ford increased the warranty to 100,000 miles and 5 years from problems with the radiator. Do you know if this is true. One dealer told me "NO". Have had to replace the radiator twice.
Old 06-11-2012, 08:10 AM
senix's Avatar
senix
senix is offline
Radiator would not be covered past the 36/36 unless if failed due to a warrantied part.
Motor is 100K/5years.
Old 06-11-2012, 02:37 PM
jraquel's Avatar
jraquel
jraquel is offline
Does this 5yr/100,000 mile cover the loss of the oil cooler?
Old 06-11-2012, 07:37 PM
senix's Avatar
senix
senix is offline
Yes..it is part of the motor.
Old 06-11-2012, 11:56 PM
jraquel's Avatar
jraquel
jraquel is offline
My dealer says there is no 5 yr/100,000 mile warranty on this engine. How can I prove to them that it is?
Old 06-12-2012, 12:00 AM
parkland's Avatar
parkland
parkland is offline
Did you buy it new?
Maybe previous owner voided the warranty?
Old 06-12-2012, 12:10 AM
jraquel's Avatar
jraquel
jraquel is offline
Yes I bought it brand new off the showroom floor.
Old 06-12-2012, 12:28 AM
parkland's Avatar
parkland
parkland is offline
when exactly?
I think some 2008's are out of engine warranty.
You can always call ford and give them your vin and ask for info, but the dealership should be able to provide the same I believe.
Old 06-12-2012, 04:56 AM
senix's Avatar
senix
senix is offline
Old 06-12-2012, 08:05 AM
jraquel's Avatar
jraquel
jraquel is offline
Thanks Senix,
I have been trying to get this information since I have been having problems with this truck. Now I need to find the exact date when I bought this truck and re-visit my dealer.
The truck is not drivable. Is the dealer obligated to haul it to their shop?
Thanks and Have a Great day,
jraquel
Old 06-12-2012, 08:51 AM
senix's Avatar
senix
senix is offline
Thanks Senix,
jraquel
First steps...put your vin in here...if under 5 years from this date.
Untitled Page=
Old 06-12-2012, 09:22 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
yes some of the first 2008 models were actually sold in early 2007 which would mean those would be out of warranty. Did you ever find out when you bought it? Warranty starts at that point.
Quick Reply: 2008 Super Duty F250 6.4 L Diesel Problems
