Bent push rods 390 - Ford Truck Enthusiasts Forums
Bent push rods 390
Old 06-04-2012, 05:43 PM
Fred Case Fred Case is offline
Fred Case is starting off with a positive reputation.
Bent push rods 390
pulled head on a 390 with 3 bent pusrods ( all intake, from each bank ) All valves fine, re did all guides , tested springs, , no binding, reassembled ran great for less than 100 miles, a bad miss, 2 different push rods bent (intake each bank ) spinning up oil pump (2000rpm) with lifters in, head on, intake off, rocker assembly off, oil pressure sits at 45psi, no spike to point to a bad oil pump valve, rocker shafts not scored, lifter / cam surface no were , flat lifter face, oil used GTX 10w30, never synthetic but changed regularly @5000miles
Old 06-04-2012, 06:25 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Old 06-04-2012, 07:14 PM
The "dirty little secret" is a procedure that was fallowed for 1st head replacment and gives no explanation or theory as to the reason for a untouched 390 bending 3 push rods after 50,000 well maintained miles.or a reason for the shorter life of replacements.
Note* All old push rods (3 straighten ) are the same length
Old 06-04-2012, 08:02 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Did you have the head's off ??
Old 06-04-2012, 10:04 PM
Blue and White Blue and White is online now
Blue and White is gaining momentum as a positive member of FTE.
My one experience with bent pushrods was on a marine engine. Long story short it was not laid up correctly for winter. On spring startup it bent a couple of pushrods as a result of corrosion between the valve guide and head. Valves were effectivly frozen. I imagine inadequate valve to guide clearance could cause the same problem... the valve basically locks up when warm.
It required head re-build and new/used pushrods to get it going again.
Old 06-04-2012, 10:50 PM
YES ! Both (2) heads , one from each side of the motor ( engine ) had been , removed, taken off as described in " Ford's dirty little secret " in an attempt to diagnose the reason for the bent push rods on the well maintained , 50,000 mile motor, no burrs on stems, or any other damage as in valve / piston kissing, valve spring not binding, rocker arm shaft rolls straight, no ridges or burrs, replaced valve guides as long as the valves were out. Replaced bent push rods drove for less than 100 miles lightly and different push rods bent.
don't feel bad if this stumps you, Two prominent race engine builders , 1 car, 1 airplane, Napafix and a Ford Dealership have no ideas
Old 06-04-2012, 11:29 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
The pistons aren't showing "witness" marks from valve to piston contact?
You sure the cam is correctly installed?
Are you tightening down the rocker shaft correctly?
Trying to spin the engine past 5000 rpm with an RV cam?
Josh
Old 06-04-2012, 11:57 PM
As mentioned , NO CONTACT OF VALVE TO PISTON
As mentioned, Installation proceduer was fallowed as Noted in " Ford dirty little secret"
As mentiond, the push rods bent after 50,000 well maintained miles,NO CAMSHAFT WAS CHANGED
As mentioned, LIGHTLY USED
Old 06-05-2012, 12:08 AM
Bullitt390's Avatar
Then worn exhaust cam lobes from using the wrong low zinc modern energy conserving engine oil, which causes excessive combustion pressures... which equals bent intake pushrods.
Use diesel oil from now on.
Josh
Old 06-05-2012, 07:37 AM
Tees77f150's Avatar
Tees77f150 Tees77f150 is offline
Tees77f150 is gaining momentum as a positive member of FTE.
I had the same problem with my 300 I6 after setting in a barn for 18-22 years. The more I ran it, the more it bent push rods. I knew it was time for a rebuild. However, I don't know if this would apply to the OP, he has well maintained his engine for all these mile and suddenly bent push rods.
I remember a friend had this problem years ago, but he was putting large cams in his small block and running at high rpm's when it happened.
Please keep us posted on your findings, best of luck and maybe we can all learn something here.
Old 06-05-2012, 08:38 AM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
jacks61ford is starting off with a positive reputation.
old gas varnishing the valves causing bent pushrods
Old 06-05-2012, 08:53 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Have you ever actually checked each valve to see just how much preload is on each lifter ? Checking the way that article says does nothing as far as I'm concerened to set preload which at tdc on each valve should be IMO .020-.040. I've built more than a few FE motors over the years in my shop and always set preload the same as any other motor, a little different procedure with FE's but I'm only concerened with actual lifter preload = how much the push rod pushes the lifters plunger down at that cylinders TDC.
Old 06-05-2012, 09:45 AM
The lack of zinc = cam lobe wear is a good one, I think measuring cam lift at this time may be the next step, as I am looking for a existing problem , not a problem that occurred after assembly ie. pre loading lifters
Bent push rods Tinytune812 1973 - 1979 F-100 & Larger F-Series Trucks 29 02-22-2017 04:25 PM
How do I diagnose and replace a bent push rod? doug42190 6.0L Power Stroke Diesel 12 06-10-2016 10:25 AM
390 Bending Push Rods DutchmanAZ FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 17 09-30-2014 11:51 AM
Intake valves sticking webslinger67 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-14-2013 03:47 PM
390 ticking after alot of work? gearheadFord FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 14 12-23-2011 03:00 PM
Tags
1996, 317, 390, bent, block, change, distance, engine, f150, ford, gallye, head, push, pushrods, rod, rods, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
