rekeying ignition switch - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-04-2012, 05:46 PM
madrid london's Avatar
madrid london madrid london is offline
madrid london is starting off with a positive reputation.
i have a 1973 C700 and i would like to know how to remove the tumbler. i have a paper clip!
http://www.mustangmonthly.com/techar...t/viewall.html
has text and foto description of the process
Old 06-05-2012, 06:04 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
I think you are going to need the key, I forget which way, I think you turn
to left Acc. then the paper clip it will slide right out if not turn to right n:
then go to Napa and get a new key and cylinder.
Old 06-05-2012, 07:14 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Turn to "acc", insert paperclip and pull to remove lock cylinder
Old 06-05-2012, 08:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Ford Mustang Ignition Switch Replacement - Mustang Monthly
Remove a battery cable for safety, reach behind the dash, push the spring loaded ignition switch towards you, and while holding it firm with one hand, use the other to remove the ignition switch bezel, which twists off by a quarter turn.
Now you can use the paper clip method, because the cylinder cannot be removed, until you remove the bezel.
The bezel has two notches, one larger than the other. The switch has two matching pins made as part of it. Peeps are unaware, use pliers to remove it, which tears out one or both of the notches.
C3TZ-11584-A .. Ignition Switch Bezel / Obsolete/Reproduced
Applications: 1961/73 C Series Tilt Cab / 1974 C Series Tilt Cab before serial number U20,001 // 1961/66 F100/1100 / 1963/69 N/NT/T500/1000 / 1966/77 Bronco / 1967/69 F800/1000.
1974 C Series from serial number U20,001 / 1975 and later C Series: The bezel (C6OZ-11584-A ~ same: 1966/67 Fairlane/Falcon / 1967/68 Mustang/Cougar) threads on/off, but you still have to press the switch towards you to remove it.
1990 F250 Aligning Ignition switch actuator rod BuckHunter1960 1987 - 1996 F150 & Larger F-Series Trucks 3 05-22-2016 04:47 PM
Replacement ignition switch bigcrunch Large Truck 1 05-08-2016 12:52 PM
Help! Ignition switch pigtail 73 ford guy 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-15-2011 04:13 PM
99 f350 install ignition switch Zephyrhills Ford 1999 - 2003 7.3L Power Stroke Diesel 1 06-26-2010 02:19 PM
How Do You Remove The Ignition Switch RedBoat Explorer, Sport Trac, Mountaineer & Aviator 6 06-27-2006 05:18 PM
Tags
1997, 1999, 87, changing, codes, cylinder, expedition, explorer, ford, forum, ignition, keying, ranger, rekey, rekeying, repinning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
