How to adjust timing - Ford Truck Enthusiasts Forums
Old 06-04-2012, 04:42 PM
Weberman3 Weberman3 is offline
Weberman3 is starting off with a positive reputation.
If anyone can tell me how to or direct me towards an artical for adjusting this. The old man thinks you have to remove a wire and a vacuum line..but we cant find any direct info on it.
Any help is appreciated.
92' F150 5.0L
Old 06-04-2012, 04:53 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Assuming you have a timing light and know how to use it...
Attach timing light.
Loosen distributor retaining bolt and ensure the timing marks on the crank balancer are visible.
Start motor and let it settle into a steady idle.
Find the spout plug in the TFI harness* and remove it to disable computer ignition advance.
Point the light at the timing marks and rotate the distributor to the desired setting.
Snug the distributor retainer nut and ensure the timing hasn't moved, and then re-insert the spout plug and ensure computer timing advance is restored.
Shut off motor and disconnect timing light.
*The spout plug is a little grey jumper located in the TFI(ignition module) harness, which will be on the distributor if you have a distributor mounted module, or on the drivers side inner fender near the hood hinge if the truck has a remote TFI.
Old 06-04-2012, 06:26 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
X2 for what Paul said. Ryan has some info with pics/drawings here: Fuel Injection Technical Library Setting the timing
Old 06-04-2012, 09:44 PM
RIKIL's Avatar
RIKIL RIKIL is offline
RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.
Quote:
I would do the previous steps but then turn off the motor, remove the spout plug and then start the motor to check the timing. Was that wrong or can it be done both ways? (you had the motor running when you pulled this plug)
Old 06-05-2012, 07:45 AM
Intimnasc's Avatar
Intimnasc Intimnasc is offline
Intimnasc is gaining momentum as a positive member of FTE.
At the risk of not wanting to hijack your thread I had a couple of questions on this issue. I have read where some people set their timing a little higher at say 12 degrees or so. If I do this what are the pros and cons as far as mileage versus towing and such?
1994 F150 4.9L E40D
Old 06-05-2012, 08:22 AM
Conanski's Avatar
Quote:
There is usually no issue with doing it either except that sometimes the motor is harder to get running with the advance disabled. There is no harm in removing the spout while the engine is running, it may set a code but clearing that is easy, so shutting it off to remove or replace it is just another unnecessary step.
Old 06-05-2012, 08:27 AM
Conanski's Avatar
Quote:
1994 F150 4.9L E40D
Advancing the timing past the factory setting will produce more TQ and improve milage but it also increases the chances of detonation under load. Every motor is different so you'll have to experiment to see what yours will handle, try 2 deg more and then test it under various conditions to see if detonation is audible, and if not try another degree or 2 and test again. When you find the setting that produces audible detonation(pinging) under load then back it off to the previous setting.
Old 06-05-2012, 09:04 AM
Intimnasc's Avatar
I'm sorry one more question and I'll quit asking so as not to take over the thread. I still live in an area with emissions testing, Will this effect my emissions negatively?
Old 06-05-2012, 09:16 AM
It shouldnt affect your emmisions if you do it right, as in still having good combustion and no detonation. if you get spark to soon I think it causes incomplete burn which is bad for emmisions.
Old 06-05-2012, 10:15 AM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
It should actually improve your emissions, as long as there is no pinging.
Old 10-07-2013, 08:19 PM
hoytaray hoytaray is offline
hoytaray is gaining momentum as a positive member of FTE.
so how do you set the timing on a truck that the timing mark bounces all over the place if you dont mind answering? thought I better edit this. I have a 1994 4.9l 5 speed
Old 10-07-2013, 09:55 PM
rla2005's Avatar
Quote:
The timing is "bouncing" around with the SPOUT removed?
Old 10-11-2013, 01:22 PM
I have been told I must be 180* out so now I am gonna set it the opposite cycle. I had set it on compressions stroke tdc so now I am gonna change it. I will tell ya what it does then. I did have the SPOUT out, yes.
Old 03-23-2015, 09:06 AM
demon216368 demon216368 is offline
demon216368 is starting off with a positive reputation.
how do i adjust the timing
Hello if someone could help me I have a 1996 Ford f150 with the 302 I would like to adjust my timing but I don't how to do it on this truck
Old 03-23-2015, 09:38 AM
RIKIL's Avatar
You should have a connector called a SPOUT connector, you will need to find out where it is on your vehicle, a google search should help. Once you find it, warm up the motor completely, turn off the motor, unplug the spout, start the motor and check the timing. Turn off motor and replace SPOUT when done.
When you remove the SPOUT, that is your base timing, the computer isn't adjusting for timing at all. When the SPOUT is connected, it tells the computer to control timing. You won't be able to get an accurate timing reading with the SPOUT connected because the computer will constantly adjust the timing as needed.
Brake assembly Question 1952 F1 Jim and Austin 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-10-2016 01:08 PM
2002 Headlight Adjusters Deluxe06 1999 - 2003 7.3L Power Stroke Diesel 7 09-19-2012 04:55 AM
How to adjust parking brake? rolloman 1997 - 2003 F150 2 03-20-2012 08:08 PM
Adjusting C6 Transmission bruno2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-28-2011 04:19 PM
C6 Transgo Reprogramming kit Band Adjustment??? bruno2 Clutch, Transmission, Differential, Axle & Transfer Case 1 11-27-2011 03:04 PM
Tags
12, 1990, 1992, 23, correct, degrees, engine, f250, find, ford, marks, set, setting, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
