Exhaust gas very hot why
I did a bunch of work to my truck
1. Had the transmission rebuilt
2. ATS ported inlet for turbo
3. Fule line crossover
4. All new boots
5. Ceramic coated pipes
6. replaced all glow plugs
before all the work it would run about 500 degrees pulling my 5th wheel trailer 65mph on flat road now it is running at 1100 degrees . A small pass I would go over before 60 mph overdrive off about 1200 degrees now 43mph second gear and 1200 degrees.
When I take off slowly it seam fine no smoke . When I go WOT it smokes like it never has before the type of smoke that stays around for awhile. pyrometer goes right to 1200 boost in only getting 17lbs. This is not pulling anything.
What would cause the exhaust gas to run hotter?
Also seam the boost is not making as much, but I have to let my foot out of it before I am sure.
Also truck as down for a 1 year ( broke transmission) so I may not be remembering how hot it was running before. but I am sure it was not any where near to this hot.
Thanks for all your help
4. All new boots
Should not have any leaks on the intake side, its not under pressure... If you do however it allows dirt to get in.
Did you install the O ring into the compressor housing when you swapped to the ATS housing?
Did you tighten the wastegate rod as the directions say when you installed the ATS housing?
I doubt the up pipes are your issue... Are they bellowed or just stockers coated?
I cant recall if the ATS housings come with a new O ring or not, been a long time...
Riffraff Diesel: GTP38 Compressor Housing O-ring
Riffraff Diesel: Garrett Compressor Housing Outlet O-ring 99.5-03
Those are what you need... Assuming there not in there.
